566
1.99k
29
190
We have been unable to configure our ModbusTCP driver to 0 address offset. Can you please advise?
We did the following:
1) Make a Context Tag (which will be the parent of the TCP driver)
2) Go to Settings, and add a property: "ModiconTypedAddr1Offset". We set the value to 0.
We have also been unable to write to coils. Could you provide an example of how to write specific bit
547
9
nadeem posted Feb 6 '18 at 8:20 am
Hello every one
I am new to VTScada
Successfully used json/xml driver to read the data from external Device
But i am stuck in how to send data ?
For example i want to send http command when button is pressed !
Any ideas ?
recent by ronniekjr  ·  Dec 6 '18 at 2:42 pm
514
The VTScada on my laptop will not run as an application.
Every time I try to launch it, I get
Error "VTScada is currently running as a service"
"Starting VTScada as an application requires stopping the service, which could disrupt other users or the operation of this installation.
It is recommended that configuration be performed on a machine that doesn't host a VTScada service.
288
I am having a problem reading tags from my OPC Server using VTScada Light. The server is located on an external PC and the connection to the client PC is made through DCOM. I know the DCOM configuration is correct because I can use Matrikon OPC Explorer on the client PC to read all the servers and tags on the external PC. I just can't replicate this within VTScada. This first screensho
5be45a8b4eb55
recent by khillbyr  ·  Nov 24 '18 at 8:22 pm
285
RodN posted Nov 20 '18 at 8:22 pm
Is CSV Import to Historian supported on VTScadaLight?
I am trying to import historic data from CSV files into some tag history. I followed all the instructions on the process, but when I restart the application, it does not load the CSV files after loading and starting the tags.
I have the CSVHistory directory in my application's Data directory, I added the TagMapping.CSV file and the on
246
genwrx posted Nov 3 '18 at 9:47 pm
Hey everyone.
I am trying to use excel to read the tag values from my application, in the example in this link https://www.trihedral.com/help/Content/D_DataSharing/D_DDEServer.htm
It says to use
=VTS|'AppName'!'TagName\Value'
For my application I would think it would be
=VTS|'HMI'!'DUPREE_WTP_DRIVER\DUP_HSP1_PDAY_RT\Value'
HMI being the app name and then the tag
Howeve
recent by genwrx  ·  Nov 8 '18 at 4:49 pm
185
jlpletcher posted Sep 25 '18 at 7:48 pm
We have an application in which the customer wishes to rearm priority 1 alarms if they stay in the alarm state for an extended period. He also would like the rearmed alarm to re-send a notification upon rearming. I have not seen anything in the manual about this being possible, but all attempts of trying it did not work. The alarm would in fact rearm, but no new notifications were sent. I had
recent by dougs  ·  Sep 27 '18 at 3:35 pm
264
We are trying to establish a connection from our clients on a local network to the primary application server. Firewalls have been disabled and I am using a LAN network for testing. Upon trying to use the access anywhere URL for our application the browser shows a window that states "establishing connection" and will not progress past this point. Any suggestions on what may be causing this is gre
recent by dougs  ·  Sep 17 '18 at 8:51 pm
141
Mel Nevergold posted Sep 14 '18 at 2:19 pm
Need a report to list alarms active in time frame that I can use with a report tag to email to bean counters.
Due to impending weather at multiple locations.
I've been trying to alter the QuarterHour,src example but the help file doesn't say where to save it so I get a file not found error importing it.
recent by dougs  ·  Sep 14 '18 at 4:53 pm
449
ellifino posted Jul 6 '18 at 6:29 pm
I have a small OEM style PLC with Modbus TCP support. VTSCADA easily reads data from the the controller. When "Enable Output" is checked however, there is no change in the PLC data table when "manual data" is entered.
A third party Modbus Simulator has no problem writing the data to the PLC.
VTS presents NO ERRORS on the Modbus Status.
Question,
The PLC Support folks say to use
159
chayes0168 posted Jun 28 '18 at 3:56 am
dear.Sir
I have 1 questions.
When i push switch button program send logic 1 to device but when I don't push switch button program still send logic 1.
I want to know how i can do for when i don't push switch button program send logic 0.
389
pbeler1 posted Jun 18 '18 at 7:55 pm
I'd like to set up a Modbus Compatible Device driver to act as a virtual PLC. I then want a separate machine to poll this virtual PLC via Modbus TCP to read the values in the Virtual PLC registers.
Is this possible - and if so, how do I set this up? I have tried creating a virtual PLC and put an analog tag with a value in there, but I cannot get a Modbus Client device to successfully connect
recent by pbeler1  ·  Jun 25 '18 at 5:11 pm
351
Hello guys,
I try to connect VTScada with my AB Micrologix 1000 PLC. It still uses serial port RS232 (I connect with USB converter-COM3).
I have tried Allen Bardley DF1 Driver. But it doesn't work. My PLC type is not available at PLC type list. But I hope they still can be connected.
Could you guys help me please.
Thanks,
5b117b83b9dab
recent by dougs  ·  Jun 20 '18 at 4:12 pm
