You can use the Alarm Status Tag to look for an active alarm, link that to a Digital Control Tag via the Data Source field of the Digital Control Tag. In the Address field of the Digital Control Tag write to the PLC and append the address with a data suffix to write to a specific bit. Please see the links below for more help on this:
I hope this helps. Please follow up if you have other questions
Alarm Status Tags:
https://www.trihedral.com/help/Content/D_Tags/Alarm-Status-Tag.htm
Digital Control Tags:
https://www.trihedral.com/help/Content/D_Tags/Dev_DigitalControl.htm
Data Suffix:
https://www.trihedral.com/help/Content/D_Tags/Dev_DataSuffixesForTagIO.htm
Pending draft
Your previous draft for topic is pending
If you continue, your previous draft will be discarded.
Add link
Upload
With selected
deselect postsshow selected posts
Selected posts
Topic:
Selected posts:
Confirm move posts
One of the posts you selected
is the main post of the topic, moving this post
will make the oldest non-moved post of
as the main topic post
You have selected all the posts from the topic, hence after moving
will be deleted
Are you sure you want to move
post(s) from the topic
to the topic
Insufficient permissions
You do not have permission to move posts to this category.
Select a different topic
You cannot move posts to the same topic.
Please go to a different topic.
Confirm selection
Are you sure you want to check this post ?
If you click 'Yes', your selection for the topic
will be cleared
