Rules and News
Thin client configuration for remote access. Where am I going wrong? URGENT!
I'm trying to access my application through remote access. I tried to do the procedure in the SSL video (https://www.youtube.com/watch?v=1DSan2ltzFg
) but without success. I'm using a domain (maizavitoria.com.br) and hosting. I'm getting an error with the SSL certificate in the manager. Where am I going wrong? Please help me. The Switch used is this one: PLANET FSD-503 (https://planet.com.br/produtos/fsd-503)
The application is already running at the factory and I need to make it work because this is the only thing missing.
THANKS
6772d58ddebdb
6772d75cb589e
6772d75cb5466
6772d75ce7d83
I'm trying to access my application through remote access. I tried to do the procedure in the SSL video (https://www.youtube.com/watch?v=1DSan2ltzFg) but without success. I'm using a domain (maizavitoria.com.br) and hosting. I'm getting an error with the SSL certificate in the manager. Where am I going wrong? Please help me. The Switch used is this one: PLANET FSD-503 (https://planet.com.br/produtos/fsd-503) The application is already running at the factory and I need to make it work because this is the only thing missing. THANKS ![6772d58ddebdb](serve/attachment&path=6772d58ddebdb) ![6772d75cb589e](serve/attachment&path=6772d75cb589e) ![6772d75cb5466](serve/attachment&path=6772d75cb5466) ![6772d75ce7d83](serve/attachment&path=6772d75ce7d83)
Hi Maiza,
If I understand correctly, you are using VTScadaLIGHT, the free version of VTScada for applications up to 50 I/O. By design, this free version requires a VPN in order to connect via the one free Thin Client connection from outside your network. This is to prevent misuse of the free license. This may be the issue.
Hi Maiza, If I understand correctly, you are using VTScadaLIGHT, the free version of VTScada for applications up to 50 I/O. By design, this free version requires a VPN in order to connect via the one free Thin Client connection from outside your network. This is to prevent misuse of the free license. This may be the issue.
25
