Productivity 1000 device driver
Is there a specific driver for the P1-540 I can use like the one used by the C-more HMI's (AutomationDirect Productivity Ethernet)? Or do I just use the generic Modbus TCP/IP?
Based on this document: https://cdn.automationdirect.com/static/specs/cutsheet/P1-540_cutsheet.pdf
It appears that VTScada should be able to communicate with that device using any of the following drivers:
-Modbus TCP
-Modbus RTU
-MQTT
Based on this document: https://cdn.automationdirect.com/static/specs/cutsheet/P1-540_cutsheet.pdf It appears that VTScada should be able to communicate with that device using any of the following drivers: -Modbus TCP -Modbus RTU -MQTT
