Application with scripting examples.
I am looking for someone who is willing to share an application with scripting examples, with the values being passed from multiple tags to the script and out of the script to multiple tags. I have looked on help files but this is not clearly defined, or am I missing something? Tried something like Scope(VTSDB, "FullTagName"\Value but it is not passing and processing the values. Intensionally missed closing bracket in Scope( as it is showing an emoji.
I am looking for someone who is willing to share an application with scripting examples, with the values being passed from multiple tags to the script and out of the script to multiple tags. I have looked on help files but this is not clearly defined, or am I missing something? Tried something like *Scope(VTSDB, "FullTagName"\Value* but it is not passing and processing the values. *Intensionally missed closing bracket in Scope( as it is showing an emoji.*
Without being able to see the closing bracket location, is this what is in the code?
Scope(\VTSDB, "FullTagName")\Value;
If you are trying to write a value to a tag, use the Set function.
https://www.vtscada.com/help/Content/Pro_Functions/Set.htm
Without being able to see the closing bracket location, is this what is in the code? ```` Scope(\VTSDB, "FullTagName")\Value; ```` If you are trying to write a value to a tag, use the Set function. https://www.vtscada.com/help/Content/Pro_Functions/Set.htm
67
