Animate pie
I want to animate a pie. My plan is to stack a white circle, then a yellow pie for power, then a small white pie, and another small colored pie on top of that so I can see how the generator speed is layered on top of the power output.
However, I don't see how to bind these things to the pie shape.
Or is there a way to color the arc meters in the gauges?
I want to animate a pie. My plan is to stack a white circle, then a yellow pie for power, then a small white pie, and another small colored pie on top of that so I can see how the generator speed is layered on top of the power output. However, I don't see how to bind these things to the pie shape. Or is there a way to color the arc meters in the gauges?
edited Jun 20 '25 at 3:34 pm
If you are using version 12.1.03 or later, try the Pie Chart. It updates dynamically. Pie charts can be found in Widgets Home->Analytics->Charts & Graphs
63
