Omron CJ2H and Ethernet/IP
Hi! I have Omron CJ2H and I've trying connect VTScada to PLC Omron via Rockwell driver as Ethernet/IP protocol, but nothing worked. What am I doing wrong?
VTScada does not support connect to Omron PLC with eth/ip protocol?
I thought it doesnt matter what is the plc I have using, if that have this protocol. I try compactlogix, controllogix, etc. (symbolic adrr.), but nothings happened. Please help.
Hi! I have Omron CJ2H and I've trying connect VTScada to PLC Omron via Rockwell driver as Ethernet/IP protocol, but nothing worked. What am I doing wrong? VTScada does not support connect to Omron PLC with eth/ip protocol? I thought it doesnt matter what is the plc I have using, if that have this protocol. I try compactlogix, controllogix, etc. (symbolic adrr.), but nothings happened. Please help.
I'm sure that won't work - why are you using the rockwell driver...?
Try reading the the below about the Omron driver, or use Modbus.
https://www.vtscada.com/help/Content/D_Tags/D_OmronFINSDriver.htm?tocpath=Reference%7CTag%20Reference%7CCommunication%20Driver%20Tags%7COmron%20FINS%20Driver%7C_____0
I'm sure that won't work - why are you using the rockwell driver...? Try reading the the below about the Omron driver, or use Modbus. https://www.vtscada.com/help/Content/D_Tags/D_OmronFINSDriver.htm?tocpath=Reference%7CTag%20Reference%7CCommunication%20Driver%20Tags%7COmron%20FINS%20Driver%7C_____0
91
