Using RS-232
I'm currently lining up hardware to experiment with VTSCADA. I'll be using an Arduino Nano for the Control and looking to communicate with VTSCADA.
Can I use the RS-232 protocol or would it be advisable to use RS-485?
The answer will provide me with a direction on the communication interface hardware.
Kind Regards - Aaron
I'm currently lining up hardware to experiment with VTSCADA. I'll be using an Arduino Nano for the Control and looking to communicate with VTSCADA. Can I use the RS-232 protocol or would it be advisable to use RS-485? The answer will provide me with a direction on the communication interface hardware. Kind Regards - Aaron
Both will work, this is more of a hardware/enviroment relevent requirment than a VTScada one - though I have only ever interfaced with RS-485.
The serial port tag references RS-232. Trihedral seems to recommend ethernet to serial converters though for redundancy (if that's required) - see https://www.vtscada.com/help/Content/D_TroubleShoot/D_Converters.htm
Both will work, this is more of a hardware/enviroment relevent requirment than a VTScada one - though I have only ever interfaced with RS-485. The serial port tag references RS-232. Trihedral seems to recommend ethernet to serial converters though for redundancy (if that's required) - see https://www.vtscada.com/help/Content/D_TroubleShoot/D_Converters.htm
51
