How to delete specific points from a history grid in a real-time application
I have a device that receives information from a sensor. The sensor information is displayed on a graph. At certain points on this device, the variable becomes negative and resets to zero. How can I exclude this negative and reset variable from the graphs so that it doesn't apply to the invoice, since it makes no difference and will end up interfering with Excel exports? (Customer request)68978d54ced45
I have a device that receives information from a sensor. The sensor information is displayed on a graph. At certain points on this device, the variable becomes negative and resets to zero. How can I exclude this negative and reset variable from the graphs so that it doesn't apply to the invoice, since it makes no difference and will end up interfering with Excel exports? (Customer request)![68978d54ced45](serve/attachment&path=68978d54ced45)
I believe that you can set the range in the tag to solve this.
Yes, it works, the problem is that I don't want the value to appear. For example, in the scale, I select (1 to 99%). Therefore, the minimum value will be 1, but I don't want that value to appear.
I would like it to hide when it reaches the minimum set value. How do I proceed?
Yes, it works, the problem is that I don't want the value to appear. For example, in the scale, I select (1 to 99%). Therefore, the minimum value will be 1, but I don't want that value to appear. I would like it to hide when it reaches the minimum set value. How do I proceed?
The best way to handle this might be to create a calculation tag which references the measured I/O and stores the modified data using a calculation.
For example, a simple ternary should handle this
[MyTag] > 1 ? [MyTag] : INVALID
note I haven't tested that code but in theory that would work.
The best way to handle this might be to create a calculation tag which references the measured I/O and stores the modified data using a calculation. For example, a simple ternary should handle this ```` [MyTag] > 1 ? [MyTag] : INVALID ```` note I haven't tested that code but in theory that would work.
I think it worked...if it's less than 5, it appears as invalid...and if it's greater than 5, the value appears...however, how do I remove the "?" when the value appears? So it doesn't end up as "16?"
68ae11fa0eda4
68ae11fa25a76
I think it worked...if it's less than 5, it appears as invalid...and if it's greater than 5, the value appears...however, how do I remove the "?" when the value appears? So it doesn't end up as "16?" ![68ae11fa0eda4](serve/attachment&path=68ae11fa0eda4) ![68ae11fa25a76](serve/attachment&path=68ae11fa25a76)
Is there also the possibility that this question "?" when it is less than 5, presents a text? Example: "Erando". It is a piece of equipment in the chemical area. @ArghDave
Oh, yes, I understand. But how do I make it display a word when it's less than 5? Without using the Questionable Flag?
I ran a test here. It's working in the calculation, the word appears when it's below 5, but it doesn't appear in the GRID plot. Does anyone know how to fix it?
68aefc44d4925
I ran a test here. It's working in the calculation, the word appears when it's below 5, but it doesn't appear in the GRID plot. Does anyone know how to fix it? ![68aefc44d4925](serve/attachment&path=68aefc44d4925)
251
8
