logs (Alarms and Events) Storage and Forwarding over UDP in light/trail version of VT SCADA.
Dear Community,
I have micrologix 1100 PLC and VT SCADA Light Version. I had communicated both SCADA and PLC. Now, I want to send logs over UDP protocol to the syslog server. i need help and step by step guidance about this.
Secondly, I want to know where VT SCADA light version stores the logs on the PC and how I can enable VT SCADA to save the logs at specific path.
Need your help please guide me.
Thanks
Dear Community, I have micrologix 1100 PLC and VT SCADA Light Version. I had communicated both SCADA and PLC. Now, I want to send logs over UDP protocol to the syslog server. i need help and step by step guidance about this. Secondly, I want to know where VT SCADA light version stores the logs on the PC and how I can enable VT SCADA to save the logs at specific path. Need your help please guide me. Thanks
If you are using the default Historian and Alarm Historian, the logs are stored by default in Application Directory->Data->History. The alarm logs are stored in [SystemAlarmHistorian] and the History logs are stored in [SystemHistorian]. Note these logs are not human readable.
Under the root of the tag tree are two tags SystemAlarmHistorian (Alarm Historian) and SystemHistorian (Historian). On the Datastore (Advanced) tab for each tag there is a field for Storage Location, enter the location here. See https://www.vtscada.com/help/Content/D_Tags/Dev_Historian.htm?cshid=20512#Historian_Settings.
See here if a third party database is being used https://www.vtscada.com/help/Content/D_LogAndReport/Dev_HistorianDataStorage.htm
If you are using the default Historian and Alarm Historian, the logs are stored by default in Application Directory->Data->History. The alarm logs are stored in [SystemAlarmHistorian] and the History logs are stored in [SystemHistorian]. Note these logs are not human readable. Under the root of the tag tree are two tags SystemAlarmHistorian (Alarm Historian) and SystemHistorian (Historian). On the Datastore (Advanced) tab for each tag there is a field for Storage Location, enter the location here. See https://www.vtscada.com/help/Content/D_Tags/Dev_Historian.htm?cshid=20512#Historian_Settings. See here if a third party database is being used https://www.vtscada.com/help/Content/D_LogAndReport/Dev_HistorianDataStorage.htm
74
