thin client portal
I am trying to use twilio to call my guys on call for system alarms but i think it cannot reach the url because the thin client will not allow me to use port 80 or 443. how do i fix this?
My understanding is that Twilio for Alarm Notification and the VTScada Thin Client are part of the same server so having both configured should still show up as on service. You'll want to make sure that VTScada is the only service listening on the port you are using.
On my PC Running Command Prompt as an Admin:
C:\Windows\System32>netstat -ano
Proto  Local Address          Foreign Address        State           PID
TCP    0.0.0.0:80             0.0.0.0:0              LISTENING       31064
TCP    [::]:80                [::]:0                 LISTENING       31064
C:\Windows\System32>tasklist /FI "PID eq 31064"
Image Name                     PID Session Name        Session#    Mem Usage
VTS.exe                      31064 Console                    5    273,928 K
My understanding is that Twilio for Alarm Notification and the VTScada Thin Client are part of the same server so having both configured should still show up as on service. You'll want to make sure that VTScada is the only service listening on the port you are using. On my PC Running Command Prompt as an Admin: ```` C:\Windows\System32>netstat -ano Proto Local Address Foreign Address State PID TCP 0.0.0.0:80 0.0.0.0:0 LISTENING 31064 TCP [::]:80 [::]:0 LISTENING 31064 ```` ```` C:\Windows\System32>tasklist /FI "PID eq 31064" Image Name PID Session Name Session# Mem Usage ========================= ======== ================ =========== ============ VTS.exe 31064 Console 5 273,928 K ````
does twilio require vtscada use 443?, I noticed you only checked 80
That was just to show as an example. I would only open port 443 and have it properly secured before opening it to the internet.
