Hi,
I'd like to use an array of tags and order it by different characteristics in script (ex. the tags with an active alarm first).
I think the best way to achieve this is by using the function GetTagList then sort that array. Unfortunately GetTagList only return an array of tag names so I can't access the tags properties. In order to sort them I would need a function that return a tag property.
I also tried to get the list of alarm tags thinking I could use that list to see which tag have active alarms but using "Alarm" as a tagType isn't working (\GetTagList("CommunAncestorName"\ShortName, TRUE, 0, "*", "Alarm" ); )
Is there a solution for my problem?
Thank you
Hi,
Thank you
edited Feb 6 '18 at 1:31 pm
