Redirect("DEF:" { The Windows default printer },
I created a printer called vtscada and configured it to print directly to a file, but when I use the "redirect" command to set it as the default printer, the program changes the default printer and crashes.
Redirect("DEF:","VTSCADA"smile { Select different printer };
If Local has a value of "DEF:", the value of this parameter has three elements separated by commas, as follows:
<printer name>, <driver name>, <port>
If I enter all three elements, I get an error message saying that too many parameters have been entered.
I created a printer called vtscada and configured it to print directly to a file, but when I use the &quot;redirect&quot; command to set it as the default printer, the program changes the default printer and crashes. Redirect(&quot;DEF:&quot;,&quot;VTSCADA&quot;) { Select different printer }; If Local has a value of &quot;DEF:&quot;, the value of this parameter has three elements separated by commas, as follows: &lt;printer name&gt;, &lt;driver name&gt;, &lt;port&gt; If I enter all three elements, I get an error message saying that too many parameters have been entered.
I started using the command prompt (cmd) to continue working with the printers.
wmic printer where name="vtsacada" call setdefaultprinter
I started using the command prompt (cmd) to continue working with the printers. wmic printer where name=&quot;vtsacada&quot; call setdefaultprinter
38
