Using VTScada as a PLC gateway?
Hello.
Is it possible to use VTScada as a PLC-to-PLC gateway,
allowing two or more PLC's to communicate with each other? If so, how can this be configured?
Thank you
Hello. Is it possible to use VTScada as a PLC-to-PLC gateway, allowing two or more PLC's to communicate with each other? If so, how can this be configured? Thank you
Prob the easiest way to do this would be to use a Slave ModbusDriver for touching tips.
How Many Time Have You Read though every function, and the source debugger?
Thank you for the responses.
My question is specifically if VTScada itself has the ability to be used as the PLC-PLC gateway.
Example: the way a RedLion Data Station would be used for PLC-PLC communication.
Thank you for the responses. My question is specifically if VTScada itself has the ability to be used as the PLC-PLC gateway. Example: the way a RedLion Data Station would be used for PLC-PLC communication.
Yes, in most cases it would be quite simple to setup.
VTScada makes for a decent I/O gateway but it depends on what you are looking for. We have the following now:
MQTT Pub/Sub
ODBC
OPC-DA (UA Server in progress)
Modbus Server (Master)
REST API (Alarms/Events/Tags/Historian
VTScada makes for a decent I/O gateway but it depends on what you are looking for. We have the following now: MQTT Pub/Sub ODBC OPC-DA (UA Server in progress) Modbus Server (Master) REST API (Alarms/Events/Tags/Historian
Thank you for that information. I appreciate it.
Using any software that runs on a Windows pc as a gateway isn’t the best practice. That being said, I’ve seen it done in a pinch.
consider using a device from RTA or Prosoft or Red Lion.
Using any software that runs on a Windows pc as a gateway isn’t the best practice. That being said, I’ve seen it done in a pinch. consider using a device from RTA or Prosoft or Red Lion.
273
7
6
