Before learning VTScada Scripting, which programming language I should be familiar?
I would like to get advice from VTScada experts regarding which programming language would be most beneficial to learn before studying VTScada scripting.
Would knowledge of C++, or another language, be helpful as a foundation?
Kindly advise. Thanks.
I would like to get advice from VTScada experts regarding which programming language would be most beneficial to learn before studying VTScada scripting. Would knowledge of C++, or another language, be helpful as a foundation? Kindly advise. Thanks.
If you are not yet skilled in a language, like I was... and you want to learn to script in VTScada, I'd start by learning VTScada script - there is lots of good examples and information in the Help files - and its structured in a decent way that you can work your way through it - if you have the time...
Reference the Scripting course (https://scadafest.com/vtscada-scripting/), "You must be comfortable with coding using an object-oriented programming language (e.g., C++, Python, Java, or JavaScript) and with basic programming concepts..."
If you are not yet skilled in a language, like I was... and you want to learn to script in VTScada, I'd start by learning VTScada script - there is lots of good examples and information in the Help files - and its structured in a decent way that you can work your way through it - if you have the time... Reference the Scripting course (https://scadafest.com/vtscada-scripting/), "You must be comfortable with coding using an object-oriented programming language (e.g., C++, Python, Java, or JavaScript) and with basic programming concepts..."
76
