Code Efficiency - Scope vs Variable
What is more efficient, scope calls with more then 1 reference, or scope call to variable.
What is the system weight on scope functions.
For Example
  IF Watch(1, Scope(Root, "Run Status")\Value);
    Value = \GetPhrase(Scope(Root, "Run Status")\DisplayValue);
OR
RunStatusVariable;
RunStatusVariable = Scope(Root, "Run Status");
  IF Watch(1, RunStatusVariable.Value);
    Value = \GetPhrase(RunStatusVariable.DisplayValue);
or if a scope is not required does it change the out come?
  IF Watch(1, \RunStatus.Value);
    Value = \GetPhrase(\RunStatus.DisplayValue);
OR
RunStatusVariable;
RunStatusVariable = \RunStatus;
What is more efficient, scope calls with more then 1 reference, or scope call to variable. What is the system weight on scope functions. For Example ```` IF Watch(1, Scope(Root, "Run Status")\Value); [ Value = \GetPhrase(Scope(Root, "Run Status")\DisplayValue); ] OR RunStatusVariable; RunStatusVariable = Scope(Root, "Run Status"); IF Watch(1, RunStatusVariable.Value); [ Value = \GetPhrase(RunStatusVariable.DisplayValue); ] ```` or if a scope is not required does it change the out come? ```` IF Watch(1, \RunStatus.Value); [ Value = \GetPhrase(\RunStatus.DisplayValue); ] OR RunStatusVariable; RunStatusVariable = \RunStatus; IF Watch(1, RunStatusVariable.Value); [ Value = \GetPhrase(RunStatusVariable.DisplayValue); ] ````
How Many Time Have You Read though every function, and the source debugger?
edited May 18 at 3:24 pm
59
