Training Simulator 12.1
I am using the Training Simulator 12.1 app to simulate a wastewater lift station as a demo for our staff. Is there a way to configure the "PLC" settings so the pumps alternate in auto instead of running simultaneously?
Thanks
I am using the Training Simulator 12.1 app to simulate a wastewater lift station as a demo for our staff. Is there a way to configure the "PLC" settings so the pumps alternate in auto instead of running simultaneously? Thanks
VTScada has pre-made station & pump status tags. Create a Station Tag (context tag wrapper) and add your pumps as children:
  1. Station Tag
    1a. Pump 1
    1b. Pump 2
Inside the station tag configuration properties, VTScada includes native parameters where you can select the number of pumps and choose an alternation mode. It's a good option if you don't quite understand writing code or expressions.
VTScada also includes a Lift Station Template with good graphics.
VTScada has pre-made station & pump status tags. Create a Station Tag (context tag wrapper) and add your pumps as children: 1. Station Tag 1a. Pump 1 1b. Pump 2 Inside the station tag configuration properties, VTScada includes native parameters where you can select the number of pumps and choose an alternation mode. It's a good option if you don't quite understand writing code or expressions. VTScada also includes a Lift Station Template with good graphics.
66
