Serial communication
I created a SerialStream in the screen's script, and the serial port can open successfully. But when I use Sersend to send data, the data isn't sent immediately—it only gets sent when I switch screens or close the project. What method should I use to force flush the send buffer?
Here's the script I tested:
Main [
Return(Self);
If Watch(0,Creat);
streamHandle = SerialStream(3 { COM3: },
1024 { Buffer 1024 bytes of received data },
1024 { Buffer 1024 bytes of transmitted data },
9600 { Baud rate },
8 { Data bits per byte },
1 { Stop bit per byte },
0 { No parity bit },
1 { Force RTS on },
0 { No Software flow control (XonXOff) },
3 { Control: DTR On, CTS control enabled });
isvalue = Valid(streamHandle);
If Watch(0,K);
sends = SerSend(3, "hello word ", 12, 0);
Thanks for answering me
I created a SerialStream in the screen's script, and the serial port can open successfully. But when I use Sersend to send data, the data isn't sent immediately—it only gets sent when I switch screens or close the project. What method should I use to force flush the send buffer? Here's the script I tested: Main [ Return(Self); If Watch(0,Creat); [ streamHandle = SerialStream(3 { COM3: }, 1024 { Buffer 1024 bytes of received data }, 1024 { Buffer 1024 bytes of transmitted data }, 9600 { Baud rate }, 8 { Data bits per byte }, 1 { Stop bit per byte }, 0 { No parity bit }, 1 { Force RTS on }, 0 { No Software flow control (XonXOff) }, 3 { Control: DTR On, CTS control enabled }); ] isvalue = Valid(streamHandle); If Watch(0,K); [ sends = SerSend(3, "hello word ", 12, 0); ] ] Thanks for answering me
Have you opened this page in the source debugger and created some break points. You can hover over your variables to see their values and step through your code.
You can find a quick intro to the Source Debugger here: https://www.youtube.com/watch?v=8LKAKjEFWds&t=147s
Have you opened this page in the source debugger and created some break points. You can hover over your variables to see their values and step through your code. You can find a quick intro to the Source Debugger here: https://www.youtube.com/watch?v=8LKAKjEFWds&t=147s
