Trigger Tags
Are Trigger Tags not functional in the Light version? I am trying to set a trigger to compile a daily report, and the trigger tag value is not wanting to change.
There should be no issue with trigger tags in the light version. Make sure the Off conditions is set. Do not use a schedule. I would set it to turn off after 2 or 3 seconds. And be sure the on condition is some point in the future. It will not activate if you set it for a past date or time.
15
