ODBC Xlreporter server failed to connect to VTscada
Hi,
I have followed all instructions to connect Xlreporter to VTscada but without success! why is that? DSN is not connecting to VTscada at all! is there any support team that can have team viewer session to help or I may send change-set file to try?
Regards
Hussain
Hi, I have followed all instructions to connect Xlreporter to VTscada but without success! why is that? DSN is not connecting to VTscada at all! is there any support team that can have team viewer session to help or I may send change-set file to try? Regards Hussain
What error message are you getting when you try to test the DSN connection? We need to get that working before XLReporter will work. You should review all the steps in the help docs for setting up an ODBC connection. We need to get the DSN working before XLReporter will work.
172
