Rslinx OPC Server and DH+ plus. Using VTScada to communicate to a SLC5/04
Hi VTScada Support.
I have two questions,
  1. I have an Ethernet/IP to Data Highway Plus Converter it is ANC-100e (https://automation-networks.com/automation-networks-anc-100e-2).
It works as a controllogix gateway with a 1756 ENET and a 1756 DHRIO.
Can we work with your software? We use PCCC not CIP.
And if there is a way can you tell me how or where to look for a guide or manual?
I am trying to communicate VTScada with a SLC5/04.
  1. One of your support members said: most other gateway devices, including the Prosoft offerings, use EIP protocol which our DF1/PCCC driver doesn't support.
So if our device also uses EIP protocol, is there other way around? Like using an OPC Server? and if yes whats steps should i take?
This is the first time i use your VTScada software.
Any help will be appreciated.
Thank you.
Hi VTScada Support. I have two questions, 1. I have an Ethernet/IP to Data Highway Plus Converter it is ANC-100e (https://automation-networks.com/automation-networks-anc-100e-2). It works as a controllogix gateway with a 1756 ENET and a 1756 DHRIO. Can we work with your software? We use PCCC not CIP. And if there is a way can you tell me how or where to look for a guide or manual? I am trying to communicate VTScada with a SLC5/04. 2. One of your support members said: most other gateway devices, including the Prosoft offerings, use EIP protocol which our DF1/PCCC driver doesn't support. So if our device also uses EIP protocol, is there other way around? Like using an OPC Server? and if yes whats steps should i take? This is the first time i use your VTScada software. Any help will be appreciated. Thank you.
Hi there, the DF1 driver didn´t work. This ANC-100e and ANC-120e both units acts as a controllogix gateway. The ANC-100e connects through the ethernet to the DH+ network, meanwhile the ANC-120 connects from USB to DH+.
Is there other way?
Hi there, the DF1 driver didn´t work. This ANC-100e and ANC-120e both units acts as a controllogix gateway. The ANC-100e connects through the ethernet to the DH+ network, meanwhile the ANC-120 connects from USB to DH+. Is there other way?
51
