Dot vs \ Notation using RadioButtons
The VTScada help file indicates that the RadioButtons function should be called using the Dot notation:
\System.RadioButtons(.....);
When I attempted this implementation the radio buttons did not show up in my display. After verifying my variables I tried using the "\" notation:
\System\RadioButtons(......);
This worked.
(Full Disclosure: I'm using the VT11 era "CompletedTutorial" application as my 'Sandbox' on VT12)
The VTScada help file indicates that the RadioButtons function should be called using the Dot notation: ```` \System.RadioButtons(.....); ```` When I attempted this implementation the radio buttons did not show up in my display. After verifying my variables I tried using the "\" notation: ```` \System\RadioButtons(......); ```` This worked. (Full Disclosure: I'm using the VT11 era "CompletedTutorial" application as my 'Sandbox' on VT12)
Old application means old properties. The one you're tripping over is LocalScopeSyntax. The docs will guide you from there.
27
