Modbus union to generate Float
I recently downloaded VTScadaLIGHT in order to test a prototype device. I am writing to Modbus registers 40001 - 40010, and splitting my floating point values into 16 bit unsigned integers. How would I union them back together in VTScadaLIGHT as a floating point value?
ex)
40001 = 16 bit unsigned int
40002 = 16 bit unsigned int
union of 4001 and 40002 = Floating point
Hello, I recently downloaded VTScadaLIGHT in order to test a prototype device. I am writing to Modbus registers 40001 - 40010, and splitting my floating point values into 16 bit unsigned integers. How would I union them back together in VTScadaLIGHT as a floating point value? ex) 40001 = 16 bit unsigned int 40002 = 16 bit unsigned int union of 4001 and 40002 = Floating point
So by setting the tag to 40001/float, the modbus driver knows to use 40001 and 40002? for the float?
That's correct, adding /FLOAT at the end will allow the tag to read 4bytes = 32bits = 2 registers
see https://www.vtscada.com/help/Content/D_Tags/Dev_DataSuffixesForTagIO.htm
> So by setting the tag to 40001/float, the modbus driver knows to use 40001 and 40002? for the float? That's correct, adding **/FLOAT** at the end will allow the tag to read 4bytes = 32bits = 2 registers see https://www.vtscada.com/help/Content/D_Tags/Dev_DataSuffixesForTagIO.htm
72
