Change the Standard screen by changing the value of PLC register
Hello,I have a problem and need help,thank
I want to change the value of 40001 in PLC to switch the screen in VT. For example, when 40001=1, switch to screen 1, and when 40001=2, switch to screen 2
Hello,I have a problem and need help,thank I want to change the value of 40001 in PLC to switch the screen in VT. For example, when 40001=1, switch to screen 1, and when 40001=2, switch to screen 2
This will take a small amount of custom code but you can use the script tag to read a PLC register and set a custom module to respond to the register value.
You can learn more about these topics here:
Go To Page Hook: https://www.vtscada.com/help/Content/p_Managers/p_PageHook.htm
Script Tags: https://www.vtscada.com/help/Content/D_Tags/Dev_ScriptTags.htm
This will take a small amount of custom code but you can use the script tag to read a PLC register and set a custom module to respond to the register value. You can learn more about these topics here: Go To Page Hook: https://www.vtscada.com/help/Content/p_Managers/p_PageHook.htm Script Tags: https://www.vtscada.com/help/Content/D_Tags/Dev_ScriptTags.htm
