SQL Data Driver - IO Tag Addressing with \
What is the correct syntax for an IO tag address to read data with the SQL Data Driver when the column name in the source data base has a '\' in it?
I'm attempting to read data from one VTScada application to another, and haven't been able to get the proper syntax for a successful query. The query when viewed in the trace viewer is always cut off after the first '\'.
What is the correct syntax for an IO tag address to read data with the SQL Data Driver when the column name in the source data base has a '\' in it? I'm attempting to read data from one VTScada application to another, and haven't been able to get the proper syntax for a successful query. The query when viewed in the trace viewer is always cut off after the first '\'.
