Trouble with MQTT Decoding
I'm having trouble getting a value from a Microhard Bullet into VTSCADA from my mosquitto broker, I am trying to get the value of temperature,
  "file_format_version" : "3.1",
  "main" : [ {
    "temperature" : "43.27",
    "voltage" : "12.48",
    "uptime" : "1120074",
    "devicetime" : "2022-03-16 14:38:10 MDT"
I am using the default decoder and the address I'm trying is
Microhard++main.0.temperature
Any advice to get me going in the right direction would be appreciated
I'm having trouble getting a value from a Microhard Bullet into VTSCADA from my mosquitto broker, I am trying to get the value of temperature, ```` { "file_format_version" : "3.1", "main" : [ { "temperature" : "43.27", "voltage" : "12.48", "uptime" : "1120074", "devicetime" : "2022-03-16 14:38:10 MDT" } ], ```` I am using the default decoder and the address I'm trying is > Microhard++main.0.temperature Any advice to get me going in the right direction would be appreciated
Have you tested:
Microhard++main[0].temperature
Microhard/++main[0].temperature
I just created a dummy broker and tested it successfully using
rdstopic/++main[0].temperature
As a note, I did need to update the JSON format from your post to the following:
    "file_format_version": "3.1",
    "main": [{
        "temperature": "43.27",
        "voltage": "12.48",
        "uptime": "1120074",
        "devicetime": "2022-03-16 14:38:10 MDT"
Have you tested: ```` Microhard++main[0].temperature ---- Microhard/++main[0].temperature ```` I just created a dummy broker and tested it successfully using rdstopic/++main[0].temperature As a note, I did need to update the JSON format from your post to the following: ```` { "file_format_version": "3.1", "main": [{ "temperature": "43.27", "voltage": "12.48", "uptime": "1120074", "devicetime": "2022-03-16 14:38:10 MDT" }] } ````
edited Mar 17 '22 at 12:47 am
Dave,
That worked for me. I used;
Thank you for your help
Dave, That worked for me. I used; ```` Microhard++main[0].temperature ```` Thank you for your help
63
