Disabling of String Entry
Hello.
I have a String Entry connected to a String I/O tag.
The value of the String I/O is now my name. If I click it, it becomes editable.
But I want it to be locked, uneditable and unselectable. I can toggle Enable Output on the String I/O, this prevents editing. But the blinking dash is still there.
I have tried making a opaque square on top of the text, that can be toggled on/off. But it seems like String Entry has the setting of Allways On Top.
Any ideas?
Hello. I have a String Entry connected to a String I/O tag. ![59ba687035ca6.png](serve/attachment&path=59ba687035ca6.png) The value of the String I/O is now my name. If I click it, it becomes editable. ![59ba68a21d419.gif](serve/attachment&path=59ba68a21d419.gif) But I want it to be locked, uneditable and unselectable. I can toggle _Enable Output_ on the String I/O, this prevents editing. But the blinking dash is still there. ![59ba6985e3b9c.png](serve/attachment&path=59ba6985e3b9c.png) I have tried making a opaque square on top of the text, that can be toggled on/off. But it seems like String Entry has the setting of _Allways On Top_. Any ideas?
If you don't want it to ever be selectable, use a GUIText object to display the value of the String I/O tag.
If you want it to be selectable for only certain logged in users, assign a Privilege on the Merit tab.
If you don't want it to ever be selectable, use a GUIText object to display the value of the String I/O tag. If you want it to be selectable for only certain logged in users, assign a Privilege on the Merit tab.
157
