577
2.02k
30
15
KEchelberry posted 2 days ago at 10:50 pm
Are Trigger Tags not functional in the Light version? I am trying to set a trigger to compile a daily report, and the trigger tag value is not wanting to change.
recent by dougs  ·  1 day ago at 9:05 pm
53
I've setup voice notification for alarms which is working great. When I dial in I'm offered other features which I don't know how to configure.
The voice prompts me to enter "3 for control" or "4 for station status". If I enter 3# or 4# I'm asked for a station number then after entering a number I'm told the station doesn't exist.
Where can I read up on this? I'd like to know what a "s
recent by Boonz  ·  Aug 22 at 10:33 am
146
sparky posted Jun 29 at 8:42 pm
I've created a camera tag and pointed it to my camera. the camera is configured for it's main feed to be mjpg and other feeds have been turned off. Besides my laptop with VTScada Lite for testing, there is nothing else on the network.
The camera widget remains grey. I have tried multiple ports: 80, 8080, 8000, 554 without success. Could someone provide direction on what I may be missing?
91
Good morning Friends,
I have below data logging requirements in our current project.
Data Logging should be at 8.00AM and 8.00PM daily. Basically data logging should be event triggered at specific time of the day.
At specific interval (e.g. 15 mins) starting from the specific time. i.e. data should log at settable interval (e.g. 15 OR 30 OR 60 mins) and should start from set time (e.g. 8
recent by Sandeep  ·  Aug 11 at 12:25 pm
64
I've downloaded and installed VTScada 12.2.26. Once I got the training simulator application running. I wanted to start following along instructions from the Student Workbook: VTScada Operations & Configuration Course Guide on setting up the port and driver. It tells me to set the IP to 127.0.0.1 and the port to 501. Once I added a digital (pump running) I was expecting to see the values for
6a497d413ffd1
recent by Dave - VTScada  ·  Jul 6 at 2:45 pm
31
We would like to customize Alarm email template as per below.
Can VTScada do that? Can change email color depending on priority?
Another question is VTSCADA can write alarm emails in HTML? or Plain text only?
6a428d1fc898c
98
Observed Behavior:
When sorting by the Address column:
Tag addresses do not sort in a predictable ascending or descending sequence.
Addresses containing a slash (/) appear to trigger a partial restart of the list, but the overall ordering still does not follow a clear rule.
The resulting list is confusing and makes it difficult to locate tags by address.
A screenshot is attached for ref
6a3be426e466c
199
mburns posted Dec 29 '24 at 4:57 am
I have a script written where I'm talking to a Serial port sending and receiving messages.
Is there a way send the string response to a tag created in the Tag Browser?
I have tried using the following:
Scope(\VTSDB, "Com3\R_Status", TRUE)
Scope(\VTSDB, "h{zfoiw%7k\5dhe8xmq^m", TRUE)
It does seem to work a bit but ends up crashing VTSCADA.
Also tried it with LocalScope.
recent by TomE  ·  Jun 26 at 9:21 am
82
Hi everyone,
I'm new to VTScada and currently working on a project to migrate an existing SCADA application from Schneider Machine SCADA Expert to VTScada.
In the existing SCADA, the operator controls use a momentary push button with feedback from the PLC. When the operator presses and holds the button, a command bit is sent to the PLC. When the button is released, the command bit is rese
recent by Dave2  ·  Jun 24 at 3:39 pm
40
We currently testing the VTScada REST SQL Query function against historian data.
We are querying two tags:
MORESCO-1\CalcTags\Lumbo\LumF1\SustainedUnsched\Cust-Min:Value
MORESCO-1\CalcTags\Lumbo\LumF1\SustainedUnsched\Cust-Aff:Value
using the following SQL query:
SELECT timestamp,
'MORESCO-1\CalcTags\Lumbo\LumF1\SustainedUnsched\Cust-Min:Value' AS CustMin,
'MORESCO-1\Calc
6a37480d47d5b
86
I am trying to connect to Watlow F4T process controller. Its temperature setpoint is IEEE float, 2 registers. After testing, I found it is using BADC reversed IEEE. I chose Open Modbus TCP and Reverse IEEE Double Byte, but I don't get the correct value. I tried both relative and absolute addresses, but neither worked. Could someone help me with it? Or the LIGHT version doesn't support 2-register
recent by jcnaquin  ·  May 26 at 4:31 pm
93
Hello!
I am using the Modbus TCP driver to communicate with Schneider Electric PowerLogic / Micrologic MTZ breaker with ethernet communication module. The breaker's Modbus Standard Address is locked at 255. From the instruction manual (see image below), the Modbus TCP driver only supports addresses 1-247.
Is there some type of expression that can be used to have the Modbus TCP driv
6a0f4fc108c29
45
John003478 posted May 15 at 6:00 am
If we hosted vtscada server on cloud by renting server in Azure or AWS, how field devices at the facility (for example., PLC) will send its data to VTScada on cloud?
We'd to know detail technical and networking setup between field devices like plc to VTscada in cloud. If Trihedral has example architecture (SCADA hosted on cloud), could advise how it looks like?
We understand we might nee
131
We would like to clarify the following points related to VTScada historian storage and report export.
1) VTScada Historian Storage on NAS
We would like to confirm whether VTScada historical/tag data can be stored on a NAS (Network Attached Storage).
From VTScada documentation, we found that the Storage Location can be changed, but there is also a note stating:
“In general, d
49
sparky posted May 12 at 5:30 pm
I am looking for a way to for a user to logoff one workstation when they login to another. I am getting push back on login times being too short and the powers that be insisting on long times (4 hours or more) before they are automatically logged off. However, I've discovered that they are now either sharing one individual's login, or that person is logging in everywhere and leaving.
Either
1234 ... 29
