563
1.98k
29
150
The report tag has its "email settings" where you can manually add or remove recipients of that report.
I'd like to offer more of a self-serve option where someone can enter their email on a page/popup which would then inject an updated recipient list into the report tag or script.
Parameters or expressions aren't allowed in this field and I have yet to figure out how to push a variable
recent by Boonz  ·  Jan 15 at 8:50 pm
106
When trying to setup communications to import tags I am getting an error of "Driver Not Ready".
Also, when I try to set up tags individually, the application is unable to read from the PLC to choose the appropriate I/O.
I have noticed that I am not getting a value next to my driver, but I am getting a zero next to my port. I cannot find a reason for a value bein
694ef6ae48b2a
recent by Dave - VTScada  ·  Jan 6 at 5:20 pm
55
I created a printer called vtscada and configured it to print directly to a file, but when I use the "redirect" command to set it as the default printer, the program changes the default printer and crashes.
Redirect("DEF:","VTSCADA" { Select different printer };
If Local has a value of "DEF:", the value of this parameter has three elements separated by commas, as follows:
<printer
140
mike_yung posted Nov 10 '25 at 11:29 pm
Glad the spam is being dealt with.
I've posted two similar requests but both were marked as spam. If they are being reviewed please post one or the other but not both.
I didn't intend to create a duplicate & my second was an attempt to get by support request into the forum.
Also, if everything is being marked as spam perhaps a message saying your post is pending approval would b
227
I've been really curious about writing scripts within an active VTScada application, but I'm not entirely sure how to go about doing so. I tried creating a new script tag, but I really do not know how to configure the tag. I tried creating calculation tags where I can bring up the function editor and even looked at the available options that function selection provides. I recently came across a Y
66
Zihad posted Nov 13 '25 at 3:40 am
I can not take data using JSON or XML Driver. I have made this link from Google Sheet. It always show 302 for JSON Driver and 1 for XML Driver
JSON Driver Link:
https://script.google.com/macros/s/AKfycbyphn30XSQYPcDdRzKcZ1_W7XnQwVYq95fQJraa9bzkkuB8_ErQFnLlFYYkyGU52j86AA/exec
XML Driver Link:
https://docs.google.com/spreadsheets/d/1zU-v9ubtb8QH7dm1CV4e8sNwpddIsjfTh4w5VUQtJsc/gviz/tq
80
I am working on my first project, coming from a different platform of over 10 years, all this is new to me. I have done searches without any results. I just want to know how I can change the background color on a "Page Navigation" widget. I have options to change the font, but I don't see anywhere that I can change the background color. Thanks guys! I am sure it's something simple that I am overl
recent by TomE  ·  Oct 29 '25 at 8:29 pm
38
I have an application that sizes a parameterized popup window to the right side of the screen, and scales it within a designated area. On the Anywhere Client the scrollbar that automatically appears automatically scrolls to the bottom upon the parameterized popup page opening. I wanted to see if there was a way to automatically scroll it back up to the top or prevent this behavior to begin with.
54
We like our SCADA pages with control pushbuttons to open with no objects selected. This way, if someone presses enter by accident they won't start or stop any equipment.
What we used to do was create a 1x1 pixel momentary button, link it to an Analog [Calc] tag named null which doesn't do anything, then layer the other objects which be clicked on in a way that this momentary button is select
37
Tecky Pete posted Oct 18 '25 at 12:16 am
Siemens LOGO! 8 programming and software setup help!
I have a LOGO! 8 Pure (no Screen) 230RCEo, 6ED1052-2FB08-0BA0
which has a DM16 230R 6ED1055-1FB10-0BA2 connected to it.
I have LOGO!Soft Comfort 8.4 control software however I cannot find my devices in the list of units in my Network View. So currently i have a LOGO! 8.FS4 setup as a google search stated this is what i need to setup for
117
I would like to set a property on a context tag, say "PLCDriver", and it's value be "[PLCPORT01\PLANTPLC01]", which I can do.
In the children tags, that need to access the i/o, I'd like to use that value to get a driver.
If I enter \PLCDriver in the Edit Parameter Expression, it retrieves the value, but says --Missing--
If I select the same through the tag browser, it works as expecte
99
I have a MicroLogix1400 connected directly to our SCADA server utilizing the TCP/IP port of the PLC. I'm having some problems in setting up the driver and port tags. I've only had some success when using the older tags, but wanting to learn more about the Rockwell Driver tag. The port tag was easier for me to setup than the driver tag. I've pointed the connection TCP/IP Name/Address as the IP of
148
I am connecting to the network for the first time in order to build a demonstration model to present as VTSCADA's suitability for our new SCADA system and I am having an issue with connectivity which I did not face with Ignition.
I am attempting to connect to a Micrologix 1400 plc, my server is set as my laptop, in the TCP/IP Port page I have entered the network IP address and TCP/IP Port num
75
I'm a new user of VTScada and currently installed a VT light version. I want to setup Enron Modbus Communication with a RTU to read historical archive of the device. I need Technical support to setup a Enron connection in VTSCADA and how to read historical data and how to trace the communication to verify Enron query and responses?
recent by TriJim  ·  Sep 30 '25 at 2:29 pm
101
abedig posted Sep 26 '25 at 9:26 pm
I am setting up an integration between VTSCADALight and the Azure Event Grid MQTT Broker. I have provisioned a certificate and an Event Grid namespace, and demonstrated using MQTTX that I am able to connect with the certificate from my host to the Event Grid's MQTT Broker and send messages. Doing so requires specifying mqtts:// as the protocol, 8883 as the port, and using the SAN value
180
I'm needing to do an HTTP POST to a web server from VT Scada, which will reply with a JSON response.
From what I can see, the JSON/XML driver is read only, not write. I.e., can do an HTTP GET, rather than a POST.
I see there is a function called HTTPClient.HTTPSend(). How would I be able to use this function so that it operates in a similar way to the JSON/XML Driver?
Has anyone done
recent by abedig  ·  Sep 26 '25 at 8:50 pm
12345 ... 29
