542
1.92k
27
45
nhig1369 posted Jun 17 at 2:48 pm
Is there a way to access components of the PLC Alarm tag? I would like to create a widget for my ALMA blocks that show setpoints and have an analog bar showing the input value and alarm setpoints
recent by TriJim  ·  Jun 24 at 9:37 pm
35
I was looking to learn more about how to configure the various driver tags. Are there ways I can simulate physical hardware without having the hardware to learn more about configuration of the driver tags. I know that sounds very vague considering the amount of available drivers. I really want to understand everything about VTScada. I believe in doing so it will make me more a valuable asset to t
recent by TriJim  ·  Jun 24 at 5:29 pm
64
justinhunt posted Jun 21 at 1:58 am
I have a laptop, a GE-F650 relay, and a Cudy P5 cellular router (configured as the gateway for my relay and laptop) w/ a SIM card installed at my house. I have a copy of VTScadaLight on my laptop and have successfully set up a tag to read voltage measurements from the relay using modbus over the LAN.
At work we have a VTScada cloud based server which i can access via VPN from my ho
49
MatrixDS posted Jun 14 at 8:16 am
I am trying to set up a Connection between Dream Report and VTSCADA. I have looked at least one instruction/guide documentation but cannot find any. Does anyone have some information?
I am trying to use the Trihedral drivers in Dream Report to get live data and also historical data. On VTSCADA I created an account and gave it Admin rights, remote tag view, and historical retrieve access. Whe
77
VTuser posted Jun 10 at 10:33 am
I am new to VTScada. I want to call an API with URL having 2 questionable variables in URL. The response is a string type and need to be displayed in VTScada overview. How can I do it with VTScada? Is it possible with HTTPSend Get function? How to call this function from within VTScada application. Can anyone provide me a sample code.
recent by VTuser  ·  Jun 13 at 8:52 am
54
Hello everyone!
I have a noob question here. I am experimenting around with using the date selector function inside the page source code. I have got that working to the point that I can display the UTC value I want from the date selector function. This is great, but now I need to use that number elsewhere in the application.
How do I get access to this variable? I tried using the scope f
recent by Sage Jackson  ·  Jun 6 at 9:29 pm
37
VTSCADA manual shows ODBC SQL query to access VTScada data from an external application like PowerBI, Python etc with explicit timestamp. e.g.,
SELECT Timestamp, 'ModDriver1:ErrorValue' from History
WHERE Timestamp BETWEEN '2014-03-01 16:54:00' AND '2014-03-01
16:55:00'
I need to write query using relative time without using explicit hard coded timestamp. i.e. timestamp between last 1 hour o
recent by TriJim  ·  Jun 5 at 6:53 pm
20
mgleb posted Jun 2 at 9:18 pm
When I copy and paste an image, such as a pump or valve, certain portions get cut off. This occurs seemingly at random; sometimes it works perfectly, and other times it does not.
Has anyone else experienced this?
683e06c030bad
72
mgleb posted May 7 at 4:36 pm
I am attempting to use the GetAlarmStat function and following the documentation, but I want to retrieve alarm counts for the entire system, so I'm leaving the tag area blank. Has anyone tried this or can someone tell me what I might be doing wrong?
Function in use:
\FunctionLib.GetAlarmStat(\Root, "ActiveCount" )
I have also attempted to self-scope as the tag, but the res
recent by mgleb  ·  May 23 at 4:49 pm
41
Is there currently a way to enable dark mode in the Tag Browser?
If not, is this feature planned for a future update?
I’ve noticed that the Alarm Page supports dark mode with just a button click, which is great. It would be really helpful to have a similar option available in the Tag Browser for better visual comfort during extended sessions.
Thanks in advance!
73
I am currently working on a project that requires integration with IEC 61850-compliant devices (such as protection relays, transformers, and switchgear). I noticed that VTScada does not have native support for IEC 61850 drivers. Can you provide any information on whether Trihedral is planning to introduce an IEC 61850 driver in the near future?
Alternatively, are there any third-party soluti
73
Dear Sir,
We have OEM SI license. We want to remote changes at our customer site without going to go to site, staying at the office.
We found out in VTScada catalog like this.
Integrators with OEM licenses can securely VPN into a customer's system to fix problems or add functionality without the need to travel to site.
Could you please explain more details about it? Can suggest s
recent by admin  ·  May 5 at 5:33 pm
63
Hi
I have a query regarding copying the trend data. We are using VT Scada version 11.1.21 and want to copy trend data from drive C to other drive in the same PC, to empty the space as our C drive where this application is installed is full now. Anyone please let me know how can i perform this activity safely without facing some serious problems on running application.
Your prompt respons
75
mpetruskavich posted Apr 1 at 7:32 pm
Hey everyone,
Implementing a totalizer in a VTScada application at a wastewater treatment plant (no pulse output on the flow meter unfortunately) and I'm wondering if there's any way to initialize the totalizer with an initial offset as the onboard totalizer on the flow meter will have accumulated a flow total as it's been running for a couple weeks now. Worst case scenario, I could record th
recent by mpetruskavich  ·  Apr 3 at 1:33 pm
39
TomE posted Mar 9 at 9:39 am
Client has an existing BMS system which they can configure internally. They would like a VTScada system to send info (live tag values) to the BMS so security can view if an alarm is active out of hours.
I could not see any drivers or info in the help. Are there any tools that enables VTScada to act as a EtherCAT slave, or will we need to put a gateway in (Modbus TCP to EtherCAT slave) to fac
65
RayJS posted Mar 5 at 4:08 pm
Hi, Has anyone setup VTscada with an AB SLC505 over ethernet. I am struggling with understanding the configuration and receive either a 789, 3894 or no value. What would be the correct setup config for a SLC505 with IP address of 10.7.112.61.
Tried different PLC modes,Port segment paths and CIP targets and tried 44818 or 2222 TCP/IP port number each result in a error code. I can ping the add
recent by RayJS  ·  Mar 5 at 7:44 pm
123456 ... 28
