590
1.84k
27
192
Marc-Olivier posted Feb 5 '18 at 9:18 pm
I'd like to use an array of tags and order it by different characteristics in script (ex. the tags with an active alarm first).
I think the best way to achieve this is by using the function GetTagList then sort that array. Unfortunately GetTagList only return an array of tag names so I can't access the tags properties. In order to sort them I would need a function that return a tag p
161
I am very new to SCADA we are using the vtsx client to connect to the server. On some of the Windows 10 desktops when the URL to the server is typed in the program automatically adds :80 to the end and will not connect. i.e. the url is http://15.15.15.15 as soon as we hit connect it shows up a http://15.15.15.15:80
The service is running on port 80 on the server.
These computers DO
120
Windows 10 update KB4056892 prevents the VTScada Internet Client (VIC) from being launched using the VTSX desktop program on client computers with that update installed. Other VTScada Thin Client formats, including those for all mobile devices, are unaffected (see work arounds below).
Microsoft is aware of this issue (see notes about CoInitializeSecurity at https://support.microsoft.com/en-
145
Are you using VTScada Alarm Notifications while running VTScada as a Windows Service? The ability to run VTScada as a service was introduced in version 11.1. It allows an application to optionally run in the background without an active user interface.
Please note that Microsoft does not permit Windows services to access SAPI, the built-in Windows text-to-speech engine. This means that if y
276
When you try to do a "Plain Excel XLS File" report, it fails with the error "Unable to generate report. Invalid data source."
You can also get a similar response when you try to use the print wizard on the Historical Data Viewer.
It appears this is being caused by changes to the Microsoft JET drivers in an October update. The new JET drivers can be found here for 2010 -
https://www.mi
328
14
phobic posted Aug 8 '17 at 12:29 pm
Isn't there a way to lock objects, and see which object is on which layer, and lock and turn off layers. And a way to know and decide which object to chose.
I am making Widgets with 5-6 icons on top of each other at several places, opacy turned on by digital inputs, and changes affected by alarms and warnings. It is a nightmare to pick the right object.
Even on a normal page, I keep picki
recent by Keith  ·  Nov 10 '17 at 3:44 pm
144
mwong015 posted Nov 7 '17 at 8:40 am
I have created my digital input tags and drew the tags with widgets. However, the logging of the DI tags in the historical viewer is not shown unless I leave the Historical Viewer open. Hence, the DI data before I open the Historical viewer is not logged. As for the analog input tags, the tags are logged autonomously based on real-time values even the Historical Viewer is not open. How can I conf
207
mwong015 posted Nov 1 '17 at 12:57 am
I have problem connecting the SNMP driver to VTScada as well as importing the MIB file. Is there a way to troubleshoot the driver connection and the error for loading the MIBs under the SNMP address?
My port is valid but my SNMP driver is invalid.
Thanks for the help in advance.
124
jsanden posted Oct 19 '17 at 11:52 pm
What does it mean what a trend says data retrieval in progress? Everything works fine at first, but when I look at the trends after my project has been running a while none show data and say "Data Retrieval in Progress".
195
ewood1972 posted Sep 1 '17 at 7:20 pm
I have recently downloaded and installed VT SCADA on my desktop. We are about to purchase the full version and I want to do some training and testing at my desk. I have installed in on two other computers and it works fine. But for some reason on my desktop it shows the start splash screen and then just shuts down and closes before it actuals starts the program. The desktop is fairly new and
recent by ewood1972  ·  Oct 20 '17 at 3:38 pm
191
Mel Nevergold posted Oct 13 '17 at 7:45 pm
SiteDraw outer ring turns red over things like;
Socket Connection Not Ready
Socket ID is not valid
Unknown Socket Error
Which if I understand these things will generate a retry because these are TCP port devices.
How can I get these to be less scary to the end user.
I tried explaining the function of the outer ring and why it turns red, but to no avail.
According to the r
252
jsanden posted Oct 18 '17 at 10:21 pm
I started a project in VTSCADALight, but had to get a license due to the tag count. How do I activate the license on an existing installation? Couldn't find this anywhere in the software or the help files.
374
phobic posted Oct 13 '17 at 1:02 pm
Hello.
I have been having some problems with import/export of tags.
Latest problem:
Window is stuck here. Constantly processing. But I can see the changes is done in the running VTScada. Impossible to close the window, I must kill it with Task Manager.
Earlier problems:
Stuck at Exporting, never gets finished.
If I check Task Manager, I can find 1-5 instances of
