When using Parameter expression to Set High Scale value under the scaling tab of the Analog Status tags it slightly alters the value from the PLC's Tag value. The actual value is 16.4 and is just a stored REAL value not a calculated one.
Also I have to perform a mathematically pointless calculation to get the widgets to use "Tag scaling values"
timb
posted Feb 9 '19 at 6:12 pm
how can I tell if I have a runtime license or if I have a developer runtime license and I'm running in runtime?
all the new tags and new child options are grayed out.
Is there a way to reset an instance of a widget to its original size?
I grouped shapes together and now I want to know how to rotate them, if possible. The rotate icon in the ribbon is grayed out.
The text at design-time in the Multi-line text widget is wrapping, but the text is all on one line with no wrapping at runtime; how does one get the text to wrap in the Multi-line text widget at runtime?
How do you delete a page parameter?
Zack
posted Jan 11 '19 at 3:06 pm
One of our clients that we recently converted from WW (yay!) is going to upgrade servers soon. Wondering what the method is to transfer existing license from one PC/Server to another. The license was just purchased and is still under support. Thanks!
mars123
posted Nov 22 '18 at 2:39 pm
We have been unable to configure our ModbusTCP driver to 0 address offset. Can you please advise?
We did the following:
1) Make a Context Tag (which will be the parent of the TCP driver)
2) Go to Settings, and add a property: "ModiconTypedAddr1Offset". We set the value to 0.
We have also been unable to write to coils. Could you provide an example of how to write specific bit
nadeem
posted Feb 6 '18 at 8:20 am
Hello every one
I am new to VTScada
Successfully used json/xml driver to read the data from external Device
But i am stuck in how to send data ?
For example i want to send http command when button is pressed !
Any ideas ?
imran
posted Nov 26 '18 at 12:12 pm
How to call 'tag configuration/properties' window in a module/script ? (using code)
The VTScada on my laptop will not run as an application.
Every time I try to launch it, I get
Error "VTScada is currently running as a service"
"Starting VTScada as an application requires stopping the service, which could disrupt other users or the operation of this installation.
It is recommended that configuration be performed on a machine that doesn't host a VTScada service.
I am having a problem reading tags from my OPC Server using VTScada Light. The server is located on an external PC and the connection to the client PC is made through DCOM. I know the DCOM configuration is correct because I can use Matrikon OPC Explorer on the client PC to read all the servers and tags on the external PC. I just can't replicate this within VTScada. This first screensho
RodN
posted Nov 20 '18 at 8:22 pm
Is CSV Import to Historian supported on VTScadaLight?
I am trying to import historic data from CSV files into some tag history. I followed all the instructions on the process, but when I restart the application, it does not load the CSV files after loading and starting the tags.
I have the CSVHistory directory in my application's Data directory, I added the TagMapping.CSV file and the on
How can I setup a page to open on the second monitor?
genwrx
posted Nov 3 '18 at 9:47 pm
Hey everyone.
I am trying to use excel to read the tag values from my application, in the example in this link https://www.trihedral.com/help/Content/D_DataSharing/D_DDEServer.htm
It says to use
=VTS|'AppName'!'TagName\Value'
For my application I would think it would be
=VTS|'HMI'!'DUPREE_WTP_DRIVER\DUP_HSP1_PDAY_RT\Value'
HMI being the app name and then the tag
Howeve
benM
posted Nov 8 '18 at 12:53 pm
I want to send SMS to notify alarm event.
To do that, I would like to connect a GSM modem which is connect to the workstation trough a Serial-to-USB converter.
I add a Serial Port tag then SMS appliance as child but I don't really how to configure them.
Polling the three modbus radios all is fine until the second server is started (it's new) What did I miss here?
We have an application in which the customer wishes to rearm priority 1 alarms if they stay in the alarm state for an extended period. He also would like the rearmed alarm to re-send a notification upon rearming. I have not seen anything in the manual about this being possible, but all attempts of trying it did not work. The alarm would in fact rearm, but no new notifications were sent. I had
Wcrad
posted Sep 14 '18 at 9:36 pm
We are trying to establish a connection from our clients on a local network to the primary application server. Firewalls have been disabled and I am using a LAN network for testing. Upon trying to use the access anywhere URL for our application the browser shows a window that states "establishing connection" and will not progress past this point. Any suggestions on what may be causing this is gre
Need a report to list alarms active in time frame that I can use with a report tag to email to bean counters.
Due to impending weather at multiple locations.
I've been trying to alter the QuarterHour,src example but the help file doesn't say where to save it so I get a file not found error importing it.
