592
1.84k
27
95
GustavoLins posted Sep 7 '19 at 12:58 pm
Hello friends, I have a serious problem. VTS does not open on the server. I have two servers, one is a backup of the other, VTS only starts if the network cables are disconnected, clicking on RUN locks in 50% in the final step "Starting tags". Does anyone know how to solve?
VTS
51
If you seem to have lost your VIC graphics after accepting Windows build 1903, we are looking into it. As a workaround, stop the VIC. Open Internet Explorer and clear the cache.
Go to C:\Program Files (x86)\Trihedral, right click on the VTSX.exe and run it as administrator - even if you are an administrator.
Log in and run it once. Close it. You should be able to run it normally from your
131
dw2white posted Jul 29 '19 at 9:03 pm
I am working with an Omron Cj2H. Programmed analog inputs and reading into a DM. Positive values are performing okay, but as soon as I go slightly negative ( reverse flow), then the number jumps to 65535. This is telling me it is wrapping around. I have tried using negative values in the scaling, but have not been successful at this point.
I can watch the channel in the plc and it remains nega
88
graingr posted Jul 13 '19 at 5:51 pm
I am building a plant from scratch. The plant has different types of equipment and all I can see in VTScada are various pumps, valves, and motors. Has anyone built or have access to bar screens, conveyor belts, weir gates, or anything else that might be useful?
Thanks in advance!
115
Caltabiano_Angelo posted Jul 3 '19 at 9:28 am
Good Day Support Team,
Few months ago i built an application running with ModBus communication. On the laptop i made it, it works like a charm.
Then i've installed VTScada on another laptop, and import the project that was on my persoanl laptop on this new one.
i set up the fixed IP address as suppose to be, but i have no communication at all. I can PING the IP of the PLC, so it means
41
dw2white posted Jun 21 '19 at 1:07 am
Hello, I am evaluating VTScada for our facility and am working with the scadalight. I have not worked with Omron Plcs in many years and need some information.
My plc has some levels which are stored in a data area (ie D0700). The PLC resides on our network (ie 192.168.10.20). From the program, I do know they set the port to 2120 instead of the default 9600. I am not sure which settings to use
76
I can successfully pull up the data into Excel using ODBC connection. The SQL statement like
select * from Alarms;
is working perfectly fine. The issue is when I use 'where' statement, I get an error. The following command is giving an error.
select * from Alarms where Active = 1;
OR
select * from Alarms where 'Active' = 1;
OR
select * from Alarms where Active = '1';
72
I would like to know if there is a possibility to get the real-time information of the alarms that arrive in the system, via ODBC, a list of the alarms that arrived in a certain period of time. I've tried to understand the file alarm.db and Alarm.LOG, but it seems illegible to me. Can someone help me?
recent by dougs  ·  Jun 10 '19 at 12:11 pm
203
Hussain posted Jun 1 '19 at 1:19 pm
Dear Dave, Thanks.
Do you mean thru realm we can authenticate other users from same network? if yes then please forward the link to install odbc driver again, the one you sent is not working.
As I know ODBC is to link with third party like xlreporter.
but is it possible to run the application it self from the remote laptop? How, is it thru OPC client and server configuration? is it
264
Hussain posted May 31 '19 at 1:35 pm
Dear all,
I have installed VTSCADA light in a data logger (windows operating system) and link the logger to controller (modbus device) thru rs232.
Is there any solution to access from remote laptop?
Is ODBC or XLreporter provide this solution? is it free or at least demo for testing?
regards
Hussian
