CIP Connection to ControlLogix
I am having an issue connecting to a ControlLogix PLC. See attached pictures about the backplane configuration and the current error on VTS. Any ideas? I can provide any further information as needed.
Lastly, using a C-More touchscreen, and I can access the main CPU through 10.133.64.31, backplane port 0, easily.
5d44a52c8389c
5d44a52c82c58
5d44ad8e539c3
I am having an issue connecting to a ControlLogix PLC. See attached pictures about the backplane configuration and the current error on VTS. Any ideas? I can provide any further information as needed. Lastly, using a C-More touchscreen, and I can access the main CPU through 10.133.64.31, backplane port 0, easily. ![5d44a52c8389c](serve/attachment&path=5d44a52c8389c) ![5d44a52c82c58](serve/attachment&path=5d44a52c82c58) ![5d44ad8e539c3](serve/attachment&path=5d44ad8e539c3)
In some cases '[]' (without the quotes) is wanted for the port segment path. Also, if not already done, you may want to try plugging the network cable into the front RJ45 port.
