Windows Service detection?
Hmm... PowerShell script and dump the status into a text file? You can also write a PowerShell script to just restart the service if it is off.
Cleanest way might be a Node.js script, run a web server which provides the value and and use the XML driver to reference it.
Hmm... PowerShell script and dump the status into a text file? You can also write a PowerShell script to just restart the service if it is off. Cleanest way might be a Node.js script, run a web server which provides the value and and use the XML driver to reference it.
46
