596
1.85k
27
83
I created a tag and then deleted it, but wanted to remake the tag again later after making some changes in a template tag. When I tried to recreate the tag I got the following error message, "A module or variable with the same name already exists. Please enter another name for this tag".
I am guessing that this error can be corrected so I can make another tag with the same name by deleting th
66
sparky.4404 posted May 12 '20 at 7:34 pm
Hi, I'm fairly new to setting up a system with VTScada, I'm using VTS 12 Lite to monitor and control small monitoring stations. The monitoring stations have the ability to detect a communications failure and save data locally. Is it possible to have this data uploaded into VTS automatically for display in the HDV?
I have seen this done before however, the situation was that there were propri
recent by Michael  ·  May 13 '20 at 3:16 pm
82
mattn posted Apr 9 '20 at 3:30 pm
New to VTscada trying to figure out how somethings are done in this environment.
Is there a tag type that is VTscada scoped? That is not being written back to a PLC.
For example if I wanted to create a VTscada tag that an operator could interact with to reset a totalizer tag, what type of tag would I use?
83
Keith Donaldson is an Engineer and Head of Business Management at the Trihedral office in Aberdeen, UK. In this tutorial, he explains how JavaScript Object Notation (JSON) works and why its role in modern SCADA systems continues to grow. Keith will demonstrate step-by-step how to configure the VTScada JSON driver and connect to third-party data. This will include using the JSON Parser to encode a
110
8
I am working on my first application for my city's water treatment plant and distribution system. I just noticed in the developers guide it states that digital control tags do not retain their values during app restarts. Most of our pumps are started and stopped manually and I do not want anything SCADA related to shut them down. Should I use Analog control tags set to 0 and 1 for this situat
recent by Michael  ·  Mar 17 '20 at 6:56 pm
129
BDemaree posted Mar 3 '20 at 4:24 pm
I need to create an XY plot of the data from 2 tags but am having difficulty doing so. I have looked at the PlotXY function but am unsure of where to use it and how to get the arrays of data needed for the function.
recent by Victor  ·  Mar 5 '20 at 3:22 pm
138
pushpika1 posted Feb 19 '20 at 9:18 pm
hello sir,
I`m pushpika from Saudi Arabia.I have designed a scada system for my company and it is approved to implement. i am using VTscada Light version to implement this project.this project includes water flowing system with chiller lines and etc.. i am planning to use Modbus compatible device to my project instead of PLC.i have already choosen a device.but i need to make sure it will be c
recent by pushpika1  ·  Feb 25 '20 at 8:24 pm
98
mjmadsen posted Feb 24 '20 at 6:58 pm
I would like to use VTScadaLight to send process data to an OPC UA server so that other OPC UA compliant programs can have access to that data.
Does VTSLight support this functionality or do I require a fully licensed version of VTS?
If VTSLight does support this functionality is there documentation that describes how to configure it appropriately.
OPC
73
pushpika1 posted Feb 20 '20 at 8:04 pm
Hi..
i`m using vtscada light version and i have Omron NJ series plc.when i trying to setting up plc with vtscada application,it shows only two series there.C/CV series and CS/CJ series.so NJ series not supporting with vtsada?if support, how to add drivers?which one i need to select while adding drivers ?omron fins driver or omron host link plc?please let me know.thank you.
175
I attached an excerpt from the help files, but I would like to discuss it for a second.
file:///C:/VTScada/VTSHelp/Content/D_Tools/Dev_Backups.htm
If there is a single application on site, and we need a backup solution that is automatic AND shutting down and restarting the application isn't possible, is using windows file history an acceptable method for continuous backup?
Has ther
5e4c9236a66ab
108
Carmelo posted Feb 4 '20 at 5:21 pm
It was not difficult to communicate a Koyo PLC with VTScada by means of Modbus TCP, being both, PLC and VTScada in the same LAN.
However, I have not been able to communicate them when the PLC is connected to a router outside the LAN of VTScada.
I typed a public IP address and the PLC port number when configured the TCP/IP port in the VTScada.
The resulting value of TCP/IP Port is -10,06
120
pieter posted Jan 31 '20 at 3:30 pm
For a school I work on three small PLC controlled processes supervised by separate VTScada applications to manage
some food processing equipment (evaporator, powder dryer machine, autoclave) that the students have to learn to work with.
Is there a report tool for VTScada that enables me to document the details of the tags of these applications in an organized way for the project document
recent by pieter  ·  Feb 14 '20 at 12:16 pm
