593
1.84k
27
192
Paul Bailey posted Sep 23 '21 at 5:32 pm
After obtaining a certificate and verifying your domain, GoDaddy will supply you with the following files:
generated-private-key.txt
generated-csr.txt
Security Certificate.crt
(“Security Certificate” would be replaced with random characters)
You should be logged into Windows as an account with administrative privileges for these steps to work.
Place those files
74
foxychen posted Oct 18 '21 at 11:01 am
HI
I have designed a Tag group, there are about 50 tags and a modbus driver, a serial(TCP/IP) port in the group, each tag mapping to a same table to the real device.
After I copy tag groups and set different station ID,
When I connect to one device, all tags read values in one second,
when I connect to two device, some tags read values in one second, but some tags read values in
23
Careyh posted Oct 28 '21 at 11:03 pm
Can VTScada poll extended history from a Floboss / ROC RTU? Its not in the help anywhere
70
I'm using VTScada to run an application linking this software to MATLAB through Excel.
When writing from Matlab to Excel,and Excel to MATLAB, everything works fine.
When using VTScada as DDE Server,and writing data to my Excel, by using the following formula:
=VTS|'NewApplication'!'L1\Value'
I get a message telling me that I have to open VTScada,even if the problem is already runni
124
soh posted Sep 4 '21 at 4:28 pm
I already setup a simple test project for thin client remote access.
I able to connect remotely using laptop via the URL given ( VIC/MIC/anywhere.
Unfortunately i not able to access remote using mobile browser.
Please advice
6133905b305d7
121
Jerry posted Aug 19 '21 at 7:09 am
Hello, I have a VTSCADA question to ask,thank you
Tag01 is the address of 40001 from the PLC. Now I want to set the bit2 of Tag01 to 1.
I failed to do this by setbit () ,Please tell me how to achieve it,thank you
611df4502643b
recent by Jerry  ·  Aug 23 '21 at 4:20 am
105
My first post to this forum!
I have set up a DNP3 driver and configured a Digital tag. My outstation device is set up to provide a binary tag w/ packed format. However, I am not able to get a response from the index=1 tag on my VTScada Application Dashboard.
Has anyone successfully setup a DNP3 binary tag (w/ "packed" format) in VT Scada?
Any input would be MUCH appreciated.
Tha
