updata a tag value with REST WebAPI from outside
As the help page I can read tag value by REST.
Can I write a new value to a tag with the same way? Maybe it likes https://Your.ServerName.com/RealmName/REST/SQLQuery?query=UPDATE tablename ....
Thanks.
As the [help](https://www.vtscada.com/help/Content/D_LogAndReport/D_RESTQueries.htm?tocpath=Use%20VTScada%7CLog%252C%20Note%252C%20and%20Report%7CSQL%20Queries%7C_____4 "help") page I can read tag value by REST. Can I write a new value to a tag with the same way? Maybe it likes https://Your.ServerName.com/RealmName/REST/SQLQuery?query=UPDATE tablename .... Thanks.
Negative. To write a tag value using a web API, you will want to write to the tag using the JSON/XML driver.
