Victor
posted Mar 12 '18 at 7:35 pm
Is it possible for each server/station of the same VTScada application to have their own Alarm DB and Event DB?
Or is there any way so that alarms would need to be acknowledged independently on each server/station? So if an alarm is acknowledged on one server, it still shows up as unacknowledged on the other.
Thanks
Victor
I'm trying to save a report group (Save Group), with a name, but the OK button is always greyed out, no matter what tags/report types I select. Same if I use a Report tag.
Regards Mattias
Hello, can someone please take a look at the attached screen shots and let me know why there are no values for the tags "T_Room" and "DI4"? I'm connected through a USB to Modbus RTU converter. The TX and RX lights are flashing on the converter, so I know its talking to the PLC. The first four screen shots are from the PLC software. I not sure how the scaling should be set up for analog status
I was wondering if the following power meter would be able to communicate with VTScada.
https://www1.itron.com/PublishedContent/100196SP-08_SENTINEL_Multimeasurement_Meter_web.pdf
Are there any drivers that could work with this?
Aaron
I have a custom page I need to be only accessed by superAdministrators.
In order do do this, I created an application privilege and added it to the required security privilege of the page. Then I added the application privilege to the superAdministrator role.
Now I would like to hide that application privilege from regular Administrator to prevent them from managing that privilege.
I'd like to add a vertical scrollbar to my window so I can see the elements outside that window scope. I am able to display the scrollbar using VScrollbar. As I understand, VScrollbar returns a numeric value representing its position.
I tried using WindowOptions to make a vertical translation equal to my scrollbar position to no avail.
Could you tell me how to properly use VScrol
HI,
The multi instrument software displays most of the signal parameters and also perform the data logging.
We have the enquiry to get some of the parameter values (THD & SNR) in our SCADA.
Is it possible to do the same by any means - say any protocol or via pc communication port we can exchange data ?
Please do let us know , as customer requires some data logging in his SCADA of
Hi, Is there a way to edit the alarm set point for Analog Status Tag without accessing to Tag Browser? I would to set up a Numeric Value Widget for alarm set point on Page in order for user to edit if they are unable to access to Tag Browser. I tried to set up a Linked Tag Widget but unable to select property tag after configuring according to the guide available.
Your help is greatly apprec
I have configured VTScada as a SNMP agent and generated a MIB file from the application. I have followed the SNMP agent configuration according to the following steps:
SNMPAgentEnable Value = 1
SNMPAgentIPListener Value = SNMP IP Listener Tag
Create SNMP Agent Widget on Idea Studio
Generate MIB file
Load MIB file using MIB browser but unable to GET any values
Is there a solution to resolve t
Maxime
posted Feb 1 '18 at 3:59 pm
I am new to VTScada and I am testing out the scripting potential of the platform.
I started out by creating a widget that display my typical dataset linked to tags. To display that widget I used the GUITransform function.
Now I obviously don't only have one but many of those that I want to display on the same screen. Also the number will change dynamically so they will h
I'd like to use an array of tags and order it by different characteristics in script (ex. the tags with an active alarm first).
I think the best way to achieve this is by using the function GetTagList then sort that array. Unfortunately GetTagList only return an array of tag names so I can't access the tags properties. In order to sort them I would need a function that return a tag p
Glenc
posted Feb 1 '18 at 5:36 pm
I am very new to SCADA we are using the vtsx client to connect to the server. On some of the Windows 10 desktops when the URL to the server is typed in the program automatically adds :80 to the end and will not connect. i.e. the url is http://15.15.15.15 as soon as we hit connect it shows up a http://15.15.15.15:80
The service is running on port 80 on the server.
These computers DO
ICI
posted Jan 11 '18 at 2:22 pm
Missing or damaged file in repository.
Trace Item GUID 7c75a5c9-858a-4e7b-bd34-0e563c453ea0
Timestamp Thu Jan 11, 2018, 09:07:19.714 (Eastern Standard Time)
Application Unknown
Caller System\Repository\Init\GetManifestRev\ReadManifestRecord
User ID
Victor
posted Jan 9 '18 at 7:47 pm
In the Programmer's guide document, there is a "A 15-Minute Snapshot Report" section that show you can use the \SnapshotReport function to create a custom Snapshot Report. Is there an equivalent function for total report that also allow custom time frame?
Thanks
Windows 10 update KB4056892 prevents the VTScada Internet Client (VIC) from being launched using the VTSX desktop program on client computers with that update installed. Other VTScada Thin Client formats, including those for all mobile devices, are unaffected (see work arounds below).
Microsoft is aware of this issue (see notes about CoInitializeSecurity at https://support.microsoft.com/en-
Are you using VTScada Alarm Notifications while running VTScada as a Windows Service? The ability to run VTScada as a service was introduced in version 11.1. It allows an application to optionally run in the background without an active user interface.
Please note that Microsoft does not permit Windows services to access SAPI, the built-in Windows text-to-speech engine. This means that if y
dougs
posted Nov 10 '17 at 4:34 pm
When you try to do a "Plain Excel XLS File" report, it fails with the error "Unable to generate report. Invalid data source."
You can also get a similar response when you try to use the print wizard on the Historical Data Viewer.
It appears this is being caused by changes to the Microsoft JET drivers in an October update. The new JET drivers can be found here for 2010 -
https://www.mi
Hello.
After an abnormal shutdown of the pc our application don´t run anymore.
The error is Layer GUID not found.
Any opinion?
LaneCAI
posted Dec 1 '17 at 4:18 pm
Is there a way to send unacknowledged alarm status or new alarm status back to the PLC? We need to be able to set a bit in the PLC whenever a new alarm is generated. VTScada Light V11.2
I am wondering how I can read data into VTScada from a general RS232 connection given that the data packet format is known.
