Problems saving report group
Hi,
I'm trying to save a report group (Save Group), with a name, but the OK button is always greyed out, no matter what tags/report types I select. Same if I use a Report tag.
Regards Mattias
Hi, I'm trying to save a report group (Save Group), with a name, but the OK button is always greyed out, no matter what tags/report types I select. Same if I use a Report tag. Regards Mattias
Let me know if you found the answer. I have the same problem. Not sure if its related to VTScada Light or not. Nothing in the documentation about it.
After entering the group name, hit the TAB key to commit the name. The OK button should enable.
Hope that helps smile
After entering the group name, hit the TAB key to commit the name. The OK button should enable. Hope that helps :)
edited Mar 20 '18 at 2:01 pm
89
