Reading data into VTScada from a general RS232 connection
I am wondering how I can read data into VTScada from a general RS232 connection given that the data packet format is known.
What do you mean by known? If it is anything but a common protocol for one of our listed drivers, then you would have to write a custom driver for it.
We do not have a generic, read anything driver.
What do you mean by known? If it is anything but a common protocol for one of our listed drivers, then you would have to write a custom driver for it. We do not have a generic, read anything driver.
I think that's a referring to a ASCII challenge and filter response type of generic driver like Kepware's ucon driver.
The ucon driver is not nearly as easy to use as they make it out to be. [doesn't matter unless it's usable.]
I just about drove myself nutters trying to use that thing to get data from a Veeder-Root TLS [a fuel tank monitoring system present in somewhere between one half to three quarters of gas stations in North America], which has a published protocol and should have been easy if time consuming but nope.
I think that's a referring to a ASCII challenge and filter response type of generic driver like Kepware's ucon driver. The ucon driver is not nearly as easy to use as they make it out to be. [doesn't matter unless it's usable.] I just about drove myself nutters trying to use that thing to get data from a Veeder-Root TLS [a fuel tank monitoring system present in somewhere between one half to three quarters of gas stations in North America], which has a published protocol and should have been easy if time consuming but nope.
What I meant by 'known' is that I know the packet format being transmitted by the device. The device I am looking to communicate with only transmits data with the following protocols:
ASCII with Wh, HTTP GET, BIN48-NET-Time, BIN48-NET, SEG Format, BIN48-ABS, BIN32-NET, BIN32-ABS, Universal Device ISY, COSM.
What I meant by 'known' is that I know the packet format being transmitted by the device. The device I am looking to communicate with only transmits data with the following protocols: ASCII with Wh, HTTP GET, BIN48-NET-Time, BIN48-NET, SEG Format, BIN48-ABS, BIN32-NET, BIN32-ABS, Universal Device ISY, COSM.
Sorry, we don't have a driver that would use either of those. Something custom would have to be written.
What would be the best way to approach writing a driver for this application?
Writing drivers requires really advanced programming skills within our own programming language. It is not something that is a trivial project. I would recommend talking to your marketing rep about getting a quote from our engineering department.
201
6
