'WHERE' clause not working while pulling up data via ODBC into Excel
I can successfully pull up the data into Excel using ODBC connection. The SQL statement like
select * from Alarms;
is working perfectly fine. The issue is when I use 'where' statement, I get an error. The following command is giving an error.
select * from Alarms where Active = 1;
OR
select * from Alarms where 'Active' = 1;
OR
select * from Alarms where Active = '1';
I noticed "where" clause is not working at all in all other queries as well. Please let me know what is the reason. Any workaround.
I can successfully pull up the data into Excel using ODBC connection. The SQL statement like select * from Alarms; is working perfectly fine. The issue is when I use 'where' statement, I get an error. The following command is giving an error. select * from Alarms where Active = 1; OR select * from Alarms where 'Active' = 1; OR select * from Alarms where Active = '1'; I noticed "where" clause is not working at all in all other queries as well. Please let me know what is the reason. Any workaround.
80
