Equipment Widgets
I am building a plant from scratch. The plant has different types of equipment and all I can see in VTScada are various pumps, valves, and motors. Has anyone built or have access to bar screens, conveyor belts, weir gates, or anything else that might be useful?
Thanks in advance!
I am building a plant from scratch. The plant has different types of equipment and all I can see in VTScada are various pumps, valves, and motors. Has anyone built or have access to bar screens, conveyor belts, weir gates, or anything else that might be useful? Thanks in advance!
It's pretty simple to import any images you might have of these products. Paint.Net is a good free tool to make .png files with transparent backgrounds. If you have CAD software, you can probably get some great images of your components to work with.
Note that you can also purchase the asset images you need, for likely less than the cost of making them, from sites such as the following:
CanStock: https://www.canstockphoto.ca/images-photos/conveyor-belt.html
ShutterStock: https://www.shutterstock.com/search/conveyor+belt
As mentioned in the beginning. Importing these into your VTScada library is really easy, just drag and drop a single image into the idea studio or use the import tool.
It's pretty simple to import any images you might have of these products. Paint.Net is a good free tool to make .png files with transparent backgrounds. If you have CAD software, you can probably get some great images of your components to work with. Note that you can also purchase the asset images you need, for likely less than the cost of making them, from sites such as the following: CanStock: https://www.canstockphoto.ca/images-photos/conveyor-belt.html ShutterStock: https://www.shutterstock.com/search/conveyor+belt As mentioned in the beginning. Importing these into your VTScada library is really easy, just drag and drop a single image into the idea studio or use the import tool.
