Redundant server drives Polling crazy
Polling the three modbus radios all is fine until the second server is started (it's new) What did I miss here?
I responded to your direct email as well. To start -
Do you have both computers in the server list? If not, delete the app on the backup. add the backup to the server list on the primary. On the backup, do an Add New...Get from Workstation and pull the app over the primary.
Only one should be polling at a time. If that didn't work, draw the show stats button for one of the device drivers. Click on it on both servers. One of them should indicate an error - that it is only available on the polling server. If it does not and both servers are in the list, then the computers are not talking. Check your firewalls. I would start by turning them completely off to eliminate that possibility.
I responded to your direct email as well. To start - Do you have both computers in the server list? If not, delete the app on the backup. add the backup to the server list on the primary. On the backup, do an Add New...Get from Workstation and pull the app over the primary. Only one should be polling at a time. If that didn't work, draw the show stats button for one of the device drivers. Click on it on both servers. One of them should indicate an error - that it is only available on the polling server. If it does not and both servers are in the list, then the computers are not talking. Check your firewalls. I would start by turning them completely off to eliminate that possibility.
34
