597
1.85k
27
100
phobic posted Aug 31 '17 at 9:13 am
I want to use the values from scaling on a tag - in an expression.
<M251_simulator\Modbus_Driver\SensorNivå1\"Scaled Min">] / 20 * 5
or rather something like this:
[*Numeric\"Scaled Min"] / 20 * 5
This is not working. Gives an error.
What am I doing wrong.
182
phobic posted Aug 29 '17 at 2:17 pm
Hello.
I think there is some bug related to the Selector Switches. I have spent countless hours on this, and by accident found a way to make it work. Meaning this must be some bug.
If I make more than a couple Selector Switches, the next one appear with no data. Like 40310 below. I have the exact same settings, because I copy the working Switch. I only change the adress.
Scanning
238
phobic posted Aug 11 '17 at 10:15 am
I would like to use a variable that counts the number of active alarms.
GetContainerNumActive
(Alarm Manager module)
Description: Returns the number of active alarms within a hierarchy of
tags.
Returns: Numeric
Usage: Script or steady state.
Function Groups: Alarm Manager
Related to: Accumulate | GetContainerNumUnacked
Format: GetContainerNumUnacked(ContainerObj);
Parameters:
ContainerObj
Req
recent by dougs  ·  Aug 29 '17 at 3:13 pm
96
RAVEENA posted Aug 22 '17 at 8:54 am
I want to know where should we use SetBit Function and how it can be used. The syntax SetBit(Tag, 2, 1); is not working in my system. Please let me know the correct syntax and where it should be written.
274
10
phobic posted Aug 2 '17 at 12:44 pm
I have made some custom widgets with several settings, digital- and analog tags. I now entered a problem. See the widget below:
I will animate the dash-bar to move up and down according to some analog value, this is no problem. But I want everything outside the dark box to be invisible.
Inserting the widget to a page makes it look like this:
But I want it to look like this:
recent by dougs  ·  Aug 11 '17 at 1:53 pm
181
phobic posted Aug 9 '17 at 11:58 am
Why can't I use the same expression for controlling opacity on Numeric Values and images.
(Scale(Analog_verdi\LowWarning\Value, 0, 1, 0, 1) || Scale(Analog_verdi\HighWarning\Value, 0, 1, 0, 1)) && !(Scale(Analog_verdi\HighAlarm\Value, 0, 1, 0, 1) || Scale(Analog_verdi\LowAlarm\Value, 0, 1, 0, 1))
I controll the opacity on a Numeric Value and on a Text Value, and it looks like this, an
recent by dougs  ·  Aug 9 '17 at 12:50 pm
126
Is there any way to have the Numeric Entry Text box clear the contents of the entry box when the operator places the cursor in the box?
Currently, where ever the cursor is placed within the entry box that is where the cursor lands, so before the decimal ... after the decimal ... and with some operators at the helm they are not recognizing where the cursor lands and they just start typing the
recent by bignerb  ·  Aug 7 '17 at 9:47 pm
107
brandonf posted Jul 31 '17 at 10:32 pm
I was wondering how the multi color widget works with a single digital input. For some reason I can't figure out how it works. I seen in the programmers guide on how to do it with an analog input and triggers but I couldn't find it used with a digital input.
Basically I was just going to take one digital input tag from my Allen bradley plc and use the multi color widget to display when it i
recent by dougs  ·  Jul 31 '17 at 11:39 pm
129
rcherrera posted Jul 31 '17 at 4:28 am
I am new to VTScada, and I want to monitor our networked PCs at home.
I used workstation tags but the only one that is working is the local PC where VTScada is currently installed (I have it in 2 laptops but it doesnt work, although I can see them in the dropdown menu when I first configured the workstation tag.
Am I missing some steps? For example, do I need to create a parent comms tag
recent by dougs  ·  Jul 31 '17 at 11:28 pm
325
manin posted Jul 16 '17 at 11:03 am
Hello, I am trying to connect mysql database to VTScada application.
First of all, is it possible to save to database values from plc through VTScada?
I want to save temperatures through time.
If yes, I haven't manage it yet. I have created a Realm and added my current application to the realm.
I created a VTS ODBC connection at System DSN. I test the connection and obviously it retu
recent by dougs  ·  Jul 17 '17 at 12:30 pm
424
manin posted Jul 2 '17 at 11:56 am
Hello, I use VTScada Free and try to communicate with Micro 820 through CIP protocol.
I downloaded your sample, and can see that it connects to plc.
But I can't figure out how can I pass my tags.
CCW understands tags as variables. I must give a variable name and then use it.
VTScada asks for address.
I tried to pass the names I have given to variables but, no luck.
Thank you
recent by manin  ·  Jul 10 '17 at 8:05 pm
151
charris posted Jun 28 '17 at 9:26 pm
I am trying to communicate with an SNMP-enabled Ethernet switch. I added a Driver which is connected to a UDP Port, which requires a local and remote port #. Should it be 161 for both? I have imported the MIB file and created a tag, but the driver is not communicating.
Regards
recent by charris  ·  Jul 6 '17 at 9:20 pm
242
Each new version of VTScada introduces new tools and sometimes changes how older features work. Your VTScada license entitles you to upgrades for a period of time after purchase. (Maintaining a Support Plus contract provides unlimited upgrades.) You can find the end date of your paid upgrade period in the About dialog, accessible from the VTScada Application Manager.
Notes:
Please review
317
dougs posted May 31 '17 at 6:17 pm
Sync'ing the clock on a PLC with the VTSCada computer time comes up fairly often. Depending on the requirements of the PLC, there are a number of ways to do this. The easiest way for all of them require using a trigger tag in the VTScada application that will trigger at a known time. For now, call this TriggerTimeSync and set an On schedule for 01:01 am and off 2 seconds later with no off schedul
54
Tank cut-away images are designed to work with the Color Fill widget. Place a cut-away on a tank and then set the color of that cut-away to something that will be unique on the page. Orange is a great choice. Now, place a Color Fill widget on top of the cut-away and set its Changed Color to match the color of the cut-away.
The Color Fill will be visible only where it overlaps the matching co
120
Our SupportPlus team regularly answers this question:
Q: I just updated to a newer version of VTScada and now my modems no longer work!
A: Customers using the modem dialer feature of the Alarm Notification System must ensure that they apply Windows updates on a regular basis. Updates to VTScada will often include modem drivers that have been patched to work with the latest Microsoft updat
