How do I use the tank cut-away images?
Tank cut-away images are designed to work with the Color Fill widget. Place a cut-away on a tank and then set the color of that cut-away to something that will be unique on the page. Orange is a great choice. Now, place a Color Fill widget on top of the cut-away and set its Changed Color to match the color of the cut-away.
The Color Fill will be visible only where it overlaps the matching color.
Tank cut-away images are designed to work with the Color Fill widget. Place a cut-away on a tank and then set the color of that cut-away to something that will be unique on the page. Orange is a great choice. Now, place a Color Fill widget on top of the cut-away and set its Changed Color to match the color of the cut-away. The Color Fill will be visible only where it overlaps the matching color.
62
