Scaled Data Value
I want to use the values from scaling on a tag - in an expression.
<M251_simulator\Modbus_Driver\SensorNivå1\"Scaled Min">] / 20 * 5
or rather something like this:
[*Numeric\"Scaled Min"] / 20 * 5
This is not working. Gives an error.
What am I doing wrong.
I want to use the values from scaling on a tag - in an expression. ![59a7c5257665f.png](serve/attachment&amp;path=59a7c5257665f.png) ```` &lt;M251_simulator\Modbus_Driver\SensorNiv&aring;1\&quot;Scaled Min&quot;&gt;] / 20 * 5 ```` or rather something like this: ```` [*Numeric\&quot;Scaled Min&quot;] / 20 * 5 ```` This is not working. Gives an error. What am I doing wrong.
The format to get properties of a tag is [MyTagName]\PropertyName.
Just using [MyTagName], by default, returns the value property - the equivalent of [MyTagName]\Value.
You would need to do -
[<M251_simulator\Modbus_Driver\SensorNivå1>]\Scaled Min / 20 * 5
[*Numeric]\ScaledMin
Note that not all properties of tags are publicly exposed to be used in an expression.
The format to get properties of a tag is [MyTagName]\PropertyName. Just using [MyTagName], by default, returns the value property - the equivalent of [MyTagName]\Value. You would need to do - ```` [&lt;M251_simulator\Modbus_Driver\SensorNiv&aring;1&gt;]\Scaled Min / 20 * 5 [*Numeric]\ScaledMin ```` Note that not all properties of tags are publicly exposed to be used in an expression.
89
