Different Initial Pages for different machines
This one came in by email but I thought it was worth adding -
I have a couple of different machines running the same application that need to start up with different pages. Is there a way to do this?
This one came in by email but I thought it was worth adding - I have a couple of different machines running the same application that need to start up with different pages. Is there a way to do this?
If you got to Application Configuration...Edit Properties....and go to Advanced Mode.
There will be an existing entry called Page that will indicate the current start up page and the workstation will say default. Copy that entry, change the page to the new page and change the workstation to the name of the workstation you want to display that page.
You can even do it for different realms using the various internet clients. Check the Realm Display Setup tag. You can use that to set different configurations for different realms, including a different start page for each realm.
If you got to Application Configuration...Edit Properties....and go to Advanced Mode. There will be an existing entry called Page that will indicate the current start up page and the workstation will say default. Copy that entry, change the page to the new page and change the workstation to the name of the workstation you want to display that page. You can even do it for different realms using the various internet clients. Check the Realm Display Setup tag. You can use that to set different configurations for different realms, including a different start page for each realm.
72
