590
1.84k
27
199
Narciso posted Jun 27 '24 at 12:21 pm
Question: How to change the message that appears in the confirmation pop-up when the "Confirmation dialog" is enable in a button?
This is the default message:
"Are you sure you want to change the value to Running?"
This is what I would like it to say:
"Are you sure you want to issue this control action?"
What is the procedure to change the confirmation pop-up messa
667d4a66efc63
recent by Narciso  ·  Jun 28 '24 at 4:57 pm
46
gtuvar posted Jun 3 '24 at 11:57 am
Hi, I want to create custom DB to store some information. in the function call of DBSystem if I have defined 5 Number of Field attribute and stored few keys with DBAdd function. Now If I want one more field attribute and if I include that 6th field in DBSystem, will all the previous ID keys information be lost ? In my case Previous keys are lost. May you please suggest what can i do to take care
49
J_Hob posted May 17 '24 at 10:39 am
I have multiple recipes that are configured in my VTScada application. I would like these recipes to all start together with a common start request.
The two questions i have are...
Can a single bit start multiple recipes (Send values to PLC) ?
I understand a single bit can be the main source but the recipe start button needs to be linked directly to the recipe book.
Exam
37
Vitor_Ferrari posted May 16 '24 at 1:29 pm
hI, I have a plc model CP2E-N40 and a would like to access and control him using Vtscada but tem que ser via acesso remoto. Someone can help me ?
Plc are connected in the wientek modem, model MT-g01 but I can only control it remotely using cx-programmer.
59
gkehoe posted May 13 '24 at 3:35 pm
I currently have a Red Lion DA50 acting as an OPCUA server with history enabled. I am able to view the history on a trend using Unified Automation UaExpert but I am not able to get the history to populate in the VTScada history for the tag. I am not entirely sure how to set up the history address for my tag other than select it using the OPCUA selector for value. The Red Lion does not have a tab
29
Vitor_Ferrari posted May 10 '24 at 3:06 pm
Tenho um modelo clp CP2E-N40 mas não consigo conectar o VTscada a ele. Alguém pode me ajudar?
122
jbench posted May 7 '24 at 1:59 pm
I've got a tag numeric value that I need to add a comma before the last digit.
For example, 837 would need to be formatted as 83,7. The value 49837 would be 4,983,7. The value 7 would just be 7. This is how the customer wants to see the values on the screen. I know this will have to be formatted as a string but not sure how to go about it.
The CommaFormat looks to only add a comma per th
recent by Boonz  ·  May 7 '24 at 5:57 pm
68
Kevin Way posted Apr 30 '24 at 7:02 pm
I can’t seem to find a variable in the JSONXMLDriver Module that allows me to read in the JSON Response so that i can parse and manipulate the data in a .src file.
I can write my own \System.HTTPClient.HTTPSend and get ride of the JSONXMLDriver completly, but i feel like i should not have to do that. I can see the AddressAssistData and the VTSRead has the data in there, but they are pro
recent by Kevin Way  ·  Apr 30 '24 at 7:47 pm
102
jroc11 posted Apr 25 '24 at 3:06 pm
Im currently building out expressions using the If else statement. I have created a custom widget that uses and ifelse statement to determine which interval value to display on a gauge. I originally created the expression for one area and it works flawlessly, but i needed to copy it over to another area thats the same, but with different tags. When copying it over i get errors no matter what i en
662a632f56e14
recent by admin  ·  Apr 25 '24 at 5:41 pm
62
mike_yung posted Apr 24 '24 at 4:25 pm
Can anyone explain what VTScada are attempting to describe here?
https://www.vtscada.com/help/Content/Pro_Functions/Edge.htm?Highlight=edge
I can't grasp how example 2 or the notes following example 2 apply to rising &/or falling edge detection.
107
Custom trend groups don't seem to get saved with the change sets. Where are they stored?
Our customer has a standalone VTScada app which I need to integrate into a bigger system. I cloned it's changeset so I could apply my OEM layer & other things so it will play nice with others.
It's now running now, with all the others, on the triple redundant servers which serve the thin clien
recent by mike_yung  ·  Apr 24 '24 at 4:22 pm
427
pieter posted Feb 12 '19 at 4:16 pm
I want to establish a connection with a Siemens Logo! 8 PLC and in VTScada I use the Siemens S7-200 driver, Rack 0 Slot 2, CP Type None, ISO Over TCP.
What are the TSAP values I have to use in the connection setting of the LOGO 8 module (Its a somewhat older model at FS2 level)
and what is the memory mapping I must use to read Flag M1
recent by pieter  ·  Apr 11 '24 at 1:35 pm
66
kblake posted Apr 9 '24 at 5:46 pm
I have site tags with an custom additional description field. Is it possible to use this field in place of, or in addition to, the description field to populate on the site list?
For example: the attached example shows the site name, and the site description from the ID tab underneath it.
[Site Name]
[description]
My site tag has the default description field, and also an added cus
66156f7ceda82
12345678 ... 30
