Firas
posted Dec 28 '23 at 7:36 am
I am trying to create a TAG context for a group of Modbus tags.
my data type is IEEE Double Precision Floating Point (8 bytes), and I need to write an expression for the TAG address so that the address will change by the meter number;
Meter #1:
TAG1 address: 31001/Double
TAG2 address: 31005/Double
TAG3 address: 31009/Double
Meter #2:
TAG1 address: 31021
jroc11
posted Dec 15 '23 at 1:52 pm
So I've had a pulse rate tag that's been pulsing and working fine for the past few weeks with zero issues. Now all of the sudden its reading as a zero for the pulse rate. This number will fluctuate from outputting a zero to outputting the correct number at its own will. Has anyone seen this before? I feel like this could be a possible bug on VTScada's end?
hilldc
posted Dec 11 '23 at 1:32 pm
Fairly new to VTScada and I need help setting up certain tag to pull from a weather station (Columbia 420) we have.
The station keeps a running total up to 10 inches before rolling back to 0 inches. I would like to display rainfall today but the reset back to 0 has me stumped as to how to setup that tag to account for the rollover which could happen in the middle of the day.
Thanks in ad
Boa noite pessoal. Eu preciso de ajuda. Como faço para controlar um driver de motor de passo como o logotipo da Siemens 8. Obrigado
jroc11
posted Dec 5 '23 at 4:22 pm
Im currently trying to find out a way that i can make a digital tag that goes from on to off and off to on every 15 minutes or so. Is there any suggestions on what the best way to do this is. I will be pairing this tag with another one in an expression to trigger a multi write tag every 15 minutes while the day is between certain times. Any suggestions help! Thanks
jroc11
posted Nov 29 '23 at 4:17 pm
So i have an analog calculation tag that is logging data based upon the whole day. i need to to grab two values from this day, these values are from 6am- 2pm and 5:15pm-2am. What is the best way to do this? i have tried using totalizers, logging tags, triggers, history stats, but no luck. I have two digital tags setup for each shifts. They output on or off depending on if the current time is in-b
mikeb
posted Aug 28 '23 at 3:24 pm
When I attempt to add my Application to my Realm from the Thin Client/Server Setup, I receive the error "HTTP server error Unknown Error -10013" when I click Apply.
What is the cause of this error?
I am using VTScadaLight version 12.1.27
mikeb
posted Nov 29 '23 at 5:16 pm
I am attempting to configure the Thin Client/Server Setup for a new application and when I click Apply I receive the error:
"HTTP server error
Unknown Error -10013."
What can cause this? I have configured nothing except for what it prompts for on install.
gtuvar
posted Nov 24 '23 at 12:12 pm
How to go to a specific page when user sign out. e.g. I am using \SecurityManager\IsLoggedOn() and if return value of this API changes to Zero I want to go to a specific starting page
We're familiar with most SCADA software, but still learning VTSCADA. We are used to the flexibility of script to do things that native symbols and widgets do not do.
Right now, we are trying to configure a button that when clicked, will perform:
TagA = TagB. (where TagA and TagB are Analog Values)
Searching through the help files, we can only find "button" style widgets in
I need to move history from one tag to another. For reasons, I need to remove one tag and replace it with another but I need to keep the history, and it's on about 80-100 tags.
Does anyone have a strategy for migrating data from one tag into another in bulk fashion? Exporting the data, massage the date and timestamp and do the CSV import would take much too long.
Thanks.
I'm looking to see if there are any tools that can "skinny" down historical data. We are now supporting some hosts that had overly high poll rates when they were commissioned, the historian subsequently got bloated and is now using up too much HDD space.
Are there any tools available that can go back and remove swaths of data, or perhaps replace a 10 min span of 1 second data with a single a
I'm trying to add a new OPC UA client :
endpoint url : opc.tcp://10.247.10.2:4840
allow unsecured connections is on
authentification is Anonymous
inside the client certificate I created a new certificate
In the server certificate I saw an untrusted certificate and added it into the trusted ones
Now when I add this OPC UA client, the values says : 514 - Server Certificate subj
gtuvar
posted Nov 11 '23 at 5:38 am
How to access a dictionary whose variable is created in one page as a network value in another page? e.g storedpumpdata is a network value variable and it is registered in X page. now I want to access storedpumpdata via dictionarycopy function in another page.
hienho
posted Nov 9 '23 at 1:04 am
Hi everyone, How to get Value from SQL to VTScada. I tried to use SQL Query Driver but failed
Hello, I have configured a Camera tag for my system but I would like to also configure an Alarm tag to alert the users if connectivity to that Camera URL is lost. Currently, if that connectivity is lost, the video stream just appears "frozen" in the dashboard no matter how much time passes -- i.e., showing the last displayed frame as a still image. But this is the same observed behavior if the
Tames
posted Jul 20 '23 at 9:47 pm
I have tried searching in the help doc about this but I did not find anything.
I am trying to use a text box and have 1. inside of it, but it keeps erasing the period "." I am just trying to make a few text boxes to make it look like a list.
Example below
1.
2.
I tried using a f(x) and then using quotation marks, and it would work, but if I reopened the properties it automati
I have successfully received email alarm notification and sms alarm notification on my smartphone through Twilio with no additional Twilio configuration other than a Twilio phone number. Phone Calls are not being made.
I'm really hoping there is not additional programming to be made on the Twilio side.
Is there more programming than what was advertised to make call outs work, or should c
Currently we have a SCADA system working, but we want to change the IP of the devices in site (Modbus Compatible Device). When we do that, we will have to do port forwarding in the router. Instead of that, is there any way in VTScada to associate the IP Address of the device? in this way, when we change in site the IP Address, we only have to change the value in the SCADA directly inst
Sheng
posted Oct 27 '23 at 12:44 am
I would like to startup the VTScada automatically after computer restart, but it'll show pop-up window that says license expired days,
could you tell me what can I do to turn off this function?
